2 sub phase adjustment - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss 2 sub phase adjustment in the Home Theater Installation and Systems forum; 2 sub phase adjustment How do I detemine the proper phase adjustment of my two pb10s ?...
GIK Acoustics
Old 12-01-07, 05:16 PM   #1 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
jwhite8086 is offline
Old 12-02-07, 08:37 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is online now
Re: 2 sub phase adjustment
The easiest way:
Play a pure tone at your xover frequency. Use the mains and just one sub to start with. Using an SPL meter at the seating position (and with your subs in their final position), adjust phase until you get the max output level..
Repeat using the other sub.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 12-02-07, 10:24 AM   #3 (Link)
Alias: Ethan Winer
Loc: New Milford, CT, USA
Ethan Winer's Avatar
User: #1679
Ethan Winer is offline
Lightbulb Re: 2 sub phase adjustment
bpape wrote: View Post
Yes, and probably repeat both subs once or twice more too, since phase adjustments can interact.
--Ethan
RealTraps
Old 12-02-07, 01:54 PM   #4 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
Where do I get the pure tone from?
Old 12-02-07, 02:06 PM   #5 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is online now
Ethan Winer wrote: View Post
--Ethan
Right. Guess I wasn't clear. The idea was to do the 2nd one with the mains and 1st sub both already on so you're blending the 2nd sub with what you already did.
You can get a bunch of free tone generators off the web and run out of your PC. I believe Ethan still has some on his site too ready for download.
Bryan
Bryan Pape
GIK Acoustics
Old 12-02-07, 04:27 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
One of the problems with the single tone method is that you could be adding to an existing peak at the crossover frequency that makes the situation worse.
A better method would be sweep the sub and mains with REW software and adjust the phase controls for a smooth transition at the crossover.
At minimum you need to test with multiple tones above and below the crossover to be sure you're not simply creating a peak with the phase controls..
Old 12-02-07, 04:47 PM   #7 (Link)
Alias: jwhite
Loc: Houston,Texas
User: #6296
So i can use rew , when I get some time alone I want to save measurments of one sub two sub in a couple of locations . Its imposible to do this with wife and kids home.
Old 12-02-07, 05:02 PM   #8 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is online now
brucek wrote: View Post
Agreed. You may need to adjust from perfect phase later on. However, IMO it's important to get everything in the proper phase to start with and then adjust later if necessary. Adjusting peak at xover via the phase control is a tradeoff IMO of better FR for muddier bottom end. I'd prefer to get the phase correct and then lower the xover point on the sub so you leave a gap between the mains xover and the sub xover to deal with any peak. Using phase for that is usually my last resort.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Outboard phase adjustment device? brucemck2 REW Forum 3 11-25-07 04:17 PM
Sub Phase Control Warpdrv DIY Subwoofers 2 11-24-07 11:57 AM
Phase Technology lcaillo Manufacturer and Vendor Reference Information 0 05-06-07 07:43 PM
Sub Phase Effect CdnTiger REW Forum 10 03-22-07 10:40 PM
Subwoofer LFE adjustment questions... Darren Home Audio Subwoofers 62 07-28-06 07:08 PM
Mach 5 Audio
