Best bass trap insulation material - Australia - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Best bass trap insulation material - Australia in the Home Theater Installation and Systems forum; Best bass trap insulation material - Australia I've just finished building my first sub and after doing some sound measurements I have decided to make some corner ...
GIK Acoustics
Old 12-27-07, 08:36 AM   #1 (Link)
Alias: Sam
Loc: Brisbane, Qld, Australia
Blueeyedfrog's Avatar
User: #14375
Since: Dec 2007
Blueeyedfrog is online now
I've just finished building my first sub and after doing some sound measurements I have decided to make some corner bass traps. This is because I have a very uneven room response (see graph). For example, I have a big -22db dip at around 28hz or 40hz, depending upon listening position and/or sub placement.
I have examined this informative list of insulation material coefficients at: http://www.bobgolds.com/AbsorptionCoefficients.htm.
However, could people suggest the most suitable material that can be purchased in Australia?
At this stage it appears to be:
Brand: CRS Bradford - Rockwool
Product: Glasswool Anticon Roofing Blanket - R2.5 Thermofoil
Specs: 95mm thick & 0.72 at 125hz
Can anyone suggest a better alternative(s)?
I have also ordered a Behringer Feedback Destroyer.
I also would like some advice on bass trap placement. As the diagram shows, the room is a T shaped garage. It is also a laundry area. The room is made of concrete block. My car is positioned left. I have partitioned part of the garage off with a very light flat cotton curtain as shown. The corners are marked with the proposed trap positions with the exception of the bottom left corner which I may also put a half leangth trap above the laundry sink. Unfilled box shapes denote shelving areas (which could be rearranged). Sub far right, listening position in pink. Yes, there is a garage door behind the car.
I'd love to hear feedback/suggestions as to a different or better layout...
In addition to my above question re suitable insulation material, my biggest questions are:
a) should I place a trap as shown in the top left corner (is it worth it)?
b) how much does the car and light weight curtain change the room from a T into an L?
c) will the traps and/or BFD fix/improve my response?
d) are traps using triangle chunks filling the entire corner better than 4inch sheets fitted diagonally across the corner?
Cheers
HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector
Old 12-27-07, 10:10 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Best bass trap insulation material - Australia
Start with the sub in the corner and tweak seating for best response that way. Then, play with sub location to better things from there. Lastly, play with mains location (specifically distance to the wall behind them) to smooth things further.
The other null you're getting is likely off the middle of the wall behind the seating position. Consider some 6" panels there.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 12-27-07, 11:02 AM   #3 (Link)
Alias: Sam
User: #14375
Since: Dec 2007
From memory, the green line is with the sub in the corner and the LP as per the diagram. The purple line is the sub as per the diagram and the seating about 750mm (30") further back. It's really the seating position that made the most difference. I don't know if it makes any difference that the sub has two opposing PRs so one will have to face up close to a wall - is that ok?
Are you suggesting place the sub in the corner in front of a trap, or not? I haven't tried moving my mains much - they were in line with the centre speaker and facing forward but the way they are now sounds so much better for positioning (with one listener - worse for two side by side).
Your suggestion for the 6" panels on the rear wall (it does get very boomy the further one goes back) - is that in addition to placing corner bass traps or before installing the corner traps? Also, what dimensions would you suggest for the rear wall panel? I forgot to mention the ceiling height is 2.4m.
Many thanks.
Old 12-27-07, 12:17 PM   #4 (Link)
Alias: Sam
User: #14375
Since: Dec 2007
I also have a budget question. It appears that having fully filled corners is better than flat panels across the corners with airspace behind. My budget can only stretch to doing either four traps with just a single panel or two traps filled right to the corners.
Which would be the better option given that I want to dampen the lowest frequencies (around 30hz)?
If two full corners are better than four unfilled, which two corners would be the best to start on?
Cheers,
Blue
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
DIY Bass Trap....Will it Work ? Marks57 Home Audio Acoustics 27 04-17-08 01:07 PM
Bass Trap, Tried it, What a difference! tonyvdb Home Audio Acoustics 14 11-03-07 01:03 AM
measuring bass trap effectiveness Nate Home Audio Acoustics 16 09-09-07 09:57 AM
Bass trap from gypsum drywall ivo_hristev Home Audio Acoustics 3 06-04-07 05:49 AM
Bass Trap Question Bob_99 Chat Box 8 12-12-06 02:02 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203
