| Home Audio Acoustics help with peak in upper freq rangeDiscuss help with peak in upper freq range in the Home Theater Installation and Systems forum; help with peak in upper freq range I have a peak from about 3k-9k hz. Any insight as to what this is from and how to deal ... |
| | #1 (Link) | |||
| help with peak in upper freq range I have a peak from about 3k-9k hz. Any insight as to what this is from and how to deal with it? I'm assuming that it should be more inline with the curve from 400-3k. here's a graph with smoothing on. Thanks ![]() | |||
| | #2 (Link) | |||
| Re: help with peak in upper freq range The peak would certainly fall within the range of the tweeters in your mains speakers. I wouldn't put too much faith in the SPL meter above ~5KHz if it's an inexpensive Radio Shack variety. If you want to carry out full range tests with speakers, you should upgrade your microphone. Either way, it does look like your top end is a bit 'hot' to say the least. Some people might also consider your subwoofer level setting a bit 'hot' also.. ![]() brucek | |||
| | #3 (Link) | ||||
| Quote:
However, the peak might well be the real response of your loudspeakers. I've seen a lot of loudspeakers with a peak around 6 to 8 KHz. They do this intentionally to make the sound seem brighter and clearer than other speakers in the showroom. --Ethan RealTraps | ||||
| | #4 (Link) | |||
| Re: help with peak in upper freq range No, a 25db boost in bass frequencies is perfectly within spec...for rearranging furniture or stress-testing your lasik surgery. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| ecm8000 high freq problems | Kerazul | SPL Meters | Mic's | Calibration | 16 | 12-01-07 05:52 PM |
| Cannot remove peak at 80hz | lovingdvd | REW Forum | 7 | 11-19-07 04:00 PM |
| LFE/Bass below speaker Freq = Distortion or Nothing? | alexadams77 | Home Audio Speakers | 2 | 11-14-07 10:44 PM |
| Importing Low Freq Data from ETF? | Wayne Rose | REW Forum | 2 | 04-24-07 10:17 PM |
| Calculating Freq Response, never ending? | scot | REW Forum | 7 | 01-06-07 03:50 PM |
