Cylindrical (Super Chunk) Bass Trap - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Cylindrical (Super Chunk) Bass Trap in the Home Theater Installation and Systems forum; Cylindrical (Super Chunk) Bass Trap I have this posted in another thread, but thought it would be best to put it in a thread of ...
GIK Acoustics
Old 12-13-07, 08:08 PM   #1 (Link)
Alias: James
Loc: somers, ny
User: #13842
Since: Nov 2007
jr1414 is online now
I have this posted in another thread, but thought it would be best to put it in a thread of it's own.
Was considering building a sonosub LLT and corner placing it, possibly 5-6' tall (depending on the modeling) having a small gap between (approximately 6.3" from the SonoSub software) and then building a cylindrical SuperChunk style bass trap above and finishing to match the sonosub. This would essentially have the appearance of a floor mounted column and a floating column above, which would double as a bass trap.
I would treat the other corners of the room similarly to maintain some symetry in the room, configuring each as a cylindrical SuperChunk bass trap, most likely with the same gap (for symetry). I know this is kind of off topic, but has anyone tried a cylindrical SuperChunk bass trap, corner mounted? I'm curious as to whether this would be a good idea or not. I'm a complete novice when it comes to acoustical treatments, so be gentle.
Thanks.
Old 12-13-07, 08:50 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Cylindrical (Super Chunk) Bass Trap
It should work OK. My larger concern is corner loading the sub to start with where you'll maximally excite very room mode in all 3 axis.
Corners will yield the most sheer output but also normally the least smooth frequency response.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 12-14-07, 11:35 AM   #3 (Link)
Alias: jack
Loc: Chicago Suburbs, IL USA
basementjack's Avatar
User: #2649
Since: Sep 2006
basementjack is offline
The idea sounds cool, but it's going to be a lot of work (and wasted material) to cut circles out of rigid fiber glass. (superchunk is usually triangles).
In general you're probably better off buying an extra couch or recliner than putting a bunch of funky tubes in the room.
I made some round bass traps and they did very little to help.
I then got a new 3 seater couch, and moved the love seat to the side wall and could easily hear the difference in low frequency response.
Thats not to say that absorbers don't help or work, just to say, look for opportunities to use real life items as traps first, then supplement as a last resort.
- Jack
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
DIY Bass Trap....Will it Work ? Marks57 Home Audio Acoustics 27 04-17-08 01:07 PM
Question on finishing DIY chunk bass absorbers... jr1414 Home Audio Acoustics 14 12-06-07 09:17 PM
Bass Trap, Tried it, What a difference! tonyvdb Home Audio Acoustics 14 11-03-07 01:03 AM
Building super-chunk trap, is 703 good enough? 91BlckGT Home Audio Acoustics 19 10-30-07 08:09 PM
Bass Trap Question Bob_99 Chat Box 8 12-12-06 02:02 AM
Mach 5 Audio
