| Home Audio Acoustics any suggestions for draperies to help with acousticsDiscuss any suggestions for draperies to help with acoustics in the Home Theater Installation and Systems forum; any suggestions for draperies to help with acoustics I have 2 windows in my theater room and was wondering what to look for in draperies to help with ... |
| | #1 (Link) | |||
| any suggestions for draperies to help with acoustics I have 2 windows in my theater room and was wondering what to look for in draperies to help with sound absorption. Both windows are on the right side of my room. With one being directly to the right of the listening position and the other, right at the 1st reflection point. Thanks | |||
| | #2 (Link) | |||
| Re: any suggestions for draperies to help with acoustics Unlikely. I had drapes made for the windows in my room to cut down on reflections and, being made from heavy velvet, heavy cotton backing and interlined with Dacron batting, it did that but had no real effect below the midrange. For that, you need heavier, thicker stuff. | |||
| | #3 (Link) | |||
| Re: any suggestions for draperies to help with acoustics Yup. The best you can do is a heavy, thick drape as Kal described. Also, make sure that they're wide enough so that even when they're closed, they hang very full. Bryan | |||
| | #5 (Link) | |||
| Re: any suggestions for draperies to help with acoustics Yes, you can do that. I've seen 'window plugs' that are removeable (although I imagine you can make them permanent). Four inches or more would be good. Bob "There is always hope, even if it is just a fool's hope." | |||
| Thread Tools | |
Similar Threads | ||||
| My graphs - suggestions? | quenthal | REW Forum | 9 | 12-15-07 05:24 PM |
| suggestions? | tonyvdb | Care Chapel | 15 | 10-12-07 06:48 PM |
| Suggestions New Sub | srsmith | SVSound | 6 | 09-07-07 09:09 AM |
| Some graphs, any suggestions | spamula9 | REW Forum | 13 | 03-14-07 10:43 PM |
