| Home Audio Acoustics Questions on corner traps...Discuss Questions on corner traps... in the Home Theater Installation and Systems forum; Questions on corner traps... I'm new to the forum and have just built my first DIY sub. The sub's great but I have a ... |
| | #1 (Link) | |||
| Questions on corner traps... I'm new to the forum and have just built my first DIY sub. The sub's great but I have a very uneven response curve. So I think bass traps are the next step (BFD on order). I was intending to use 3 inch thick fiberglass across the corners with airspace behind but I see you have totally filled the corner. Is it better to fill the corner than leave air space or is this just a different approach? HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #2 (Link) | |||
| Re: Questions on corner traps... I have 4" Rockwool straddling my corners, and it's pretty effective. I've got more panels on the way and I'm gonna make 'proper' corner traps like the OP did. I think they'll be more effective, as there's a lot more material to absorb the energy. I'll make sure to do before and after analysis when I finish them. | |||
| | #3 (Link) | |||||
| Re: Questions on corner traps... Quote:
| | #4 (Link) | ||||
Bob "There is always hope, even if it is just a fool's hope." | ||||
| | #5 (Link) | |||
| Re: Questions on corner traps... Sorry - out of town with limited connectivity. Full corners will in fact extend the bottom end control lower in frequency. From a cost perspective when DIY'ing, the same amount of material to build a chunk will be used for 6" thick straddling panels - IOW, 50% more than a 4" panel straddling. Bryan | |||
| | #6 (Link) | |||
| Re: Questions on corner traps... Thanks everyone for your answers. If I'm not mistaken, blanket insulation appears to be cheaper than the more rigid sheets. In order to save costs would it be a good idea to use sheeting across the corner and fill the space behind with the cheaper blanket filling. Or would the blanket compress too much under its own weight? Unless you could use vertical runs (stand the insulation on end rather than stacking wedges on top of each other as done here) and glue them together to reduce sagging? Cheers, Blue HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #7 (Link) | |||
| Re: Questions on corner traps... I belive the idea with the rigid fiberglass is that it is denser than batting, thus absorbing more sound, rather than allowing it to pass through. If you have an air space anyway, I can't see any harm in it, but it would be a mess. I'm thinking of building some corners while I'm off work, but its cold out and I dont feel like wasting a hundred pounds of LP heating my shop. I wonder if anyone has done corner traps with full squares, protruding into the room. I'm trying to envision how I'd cover them. Onkyo 805 | Denon DVD-1920 | Sony 400 disc | Definitive Technology ProTower 400s | ProCenter 100 and PCC2 | BP2x | ProMonitor 100s | Klipsch RSW-10 subwoofer| Otoma HD70 | Play Station 3 | Toshiba HD-A3 | |||
| | #8 (Link) | |||
| Re: Questions on corner traps... Blanket will require more thickness to compensate for the lower density. If you want to fill the back with batting, use at least 4" of board on the front and fill in with the lower density. It's still not as good as solid 3-6lb/cu ft density material but better than just 4" straddling. Bryan | |||
| | #9 (Link) | ||||
![]() Marshall Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #10 (Link) | |||
| | Re: Questions on corner traps... Quote: I used 4 layers of 2" semi rigid fibreglass.. The inner layer is about 150mm wide and fits into the corners, and each layer gets progressively wider, to form a sort of a wedge shape, with a small amount of air space between each layer. If you want to use the US OC703 equivalent for your corner traps, you will need Bradfords "Supertel" fibreglass.. It comes in 1200x2400 2" thick sheets. costs about $70.00/sheet. Doing it this way you will only need one sheet per corner.. Home Theatre....The never ending story! Prof.. | |||
| | #11 (Link) | |||
| Re: Questions on corner traps... OK, so using blanket/batts is a bad idea. Glad I got that one straighten out. However, I'm a bit confused because I have been trying to compare coefficients of Australian products and it seems that, for a given thickness, the same density blanket has similar coefficients as the rigid board: http://www.bobgolds.com/AbsorptionCoefficients.htm As an aside, I have noticed that the Australian products appear to be nowhere as high as the US OC703/5 coefficients - why? Also, when comparing the Bradfords "Supertel" fibreglass to the Bradfords Fibertex650 the coefficents are respectively, 0.39 and 0.59, for 2" board. Surely higher coefficients are better - i.e. OC703 is around 0.60-0.80? In fact which of these would people recommend: Ultratel - 0.34, density 2.4kg/m2 Quietel - 0.36, density 6.5kg/m2 Supertel - 0.39, density 1.6kg/m2 Flexitel - 0.42, density 1.2kg/m2 Fibertex650 - 0.59, density 5kg/m2 (but horrible 11500 x 900 [4.6' x 3'] sheet sizes) or Insulco semi-rigid IB - 0.46, density ? Also, some of the coefficients change depending on whether or not the sheets are covered with foil. Presumably if stacking then foil is unnecessary/non-beneficial? I notice that higher coefficients do not correlate with higher density - which is better, higher density or higher coefficient or both high density and coefficient? I have no idea of the price variation across the different products - so that also may be a deciding factor... yes insulation is expensive here in Aus. Re using squares instead of triangles - won't that create two corners in the space where there was previously only one? Cheers, Blue EDIT: Just wanted to check my calculations to make corner wedges: My ceiling is 2400mm high 1200 x 2400 sheet = 32 triangles; 600mm (2') across the hypotenuse. 32 triangles @ 50mm thick stacks to 1600mm high 1600mm height x 3 sheets = 4800 = enough material for two floor-to-ceiling bass traps @ $70 per sheet that's $210 for two traps + covering Cheers, Blue HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #12 (Link) | |||
| Re: Questions on corner traps... When stacked, the fiberglass will compress slightly. Be prepared to have some extra in the stack, or just leave a little space at the top and use a fabric frame to cover the whole mess. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #13 (Link) | |||
| Re: Questions on corner traps... Again, for the same size triangle, a solid triangle will take the same amount as 3 2" layers straddling. Fluffy in the back is OK if you still do 4" on the front. Bryan | |||
| | #14 (Link) | |||
| Re: Questions on corner traps... Thanks Bryan, Any suggestions as to the best material to use for the straddling (Ultratel, Quietel, etc.)? Cheers, Blue HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #15 (Link) | |||||
By my calculations you only get 16 triangles with a 600mm face from a 1200x2400 sheet!! | |||||
| | #16 (Link) | |||
| Re: Questions on corner traps... Okay, I'm sorry but I've been having a hard time tracking this stuff down. Do I need to go directly to a contractor supplier, or what? Heck, the chain stores have never even heard of it. | |||
| | #17 (Link) | |||
| Re: Questions on corner traps... I don't think you can buy the stuff I mentioned above (#11) in the US. I think everyone there uses the Owens Corning 700 series Rigid Fiberglass, specifically the 703 FRK or 705 FRK, which seems to have better specs than the Australian stuff I mentioned. HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #19 (Link) | |||
| Re: Questions on corner traps... A 600 x 600 square can be cut diagonally giving 4 wedges (each with 600 across the longest face), yes? 8, 600 x 600 squares can be cut from 1, 1200 x 2400 sheet, yes? 8 x 4 = 32, no? HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #20 (Link) | |||
| Re: Questions on corner traps... Feel free to jack the thread - this one started from another thread I jacked! Here: http://www.hometheatershack.com/foru...-finished.html HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #21 (Link) | |||
| Re: Questions on corner traps... Sonnie's always on top of that, isn't he! I did that once and he created a new thread before I even checked it for replies. Very good admin skills. ![]() ![]() | |||
| | #23 (Link) | |||
| Re: Questions on corner traps... Does anyone know whether corner traps will have any effect as low as 20-25hz? Basically I have a drop off there and that's the area I want to improve. HTPC - Pentium 4 3ghz|PowerDVD ultra|Theatertek 2.6|7600gt nvidia|X-mystique DD live soundcard|NAD T743 receiver|BFDPro DSP1124P|B&W DM602 S3 x2 fronts|LCR600 S3 center|DM601 S2 rears|DIY 2 x Mach 5 Audio IXL-18 sonosubs 365ltr 15hz|Behringer EP2500 sub amp|DIY 12" Peerless dual PRs 240 Watt Sub|Mitsubishi HC1100 projector | |||
| | #24 (Link) | |||
| Re: Questions on corner traps... And while we're on the subject of faces, will longer faces (splitting a 120x60 sheet in 4, 85cm face) yield better results? Reach lower and/or provide more damping? You'd think so anyway, it's twice the amount of material. But I won't use it all if there's no real benefit. Last edited by atledreier; 12-31-07 at 01:44 AM. | |||
