Acoustics Help! - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Acoustics Help!
Discuss Acoustics Help! in the Home Theater Installation and Systems forum; Acoustics Help! It will increase the cavity depth of the enclosure but you should be cutting them off high enough (80Hz) that ...
GIK Acoustics
Old 01-08-08, 02:45 PM   #26 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
It will increase the cavity depth of the enclosure but you should be cutting them off high enough (80Hz) that it shouldn't matter.
If you leave them recessed, you'll lose some of the dispersion from the drivers.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 01-08-08, 02:50 PM   #27 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Re: Acoustics Help!
HT Crazy wrote: View Post
Why do the speakers have to be flush with the treatments? What difference will it make if they remain flush with the drywall? Can the treatments be beveled down toward the speakers? If the speakers are flush with the treatments by building them out won't that affect the performance of them, because of the enclosures?
The problem is that the panels will absorb on the sides as well, killing the horz and vert dispersion of your speakers. Beveling will help, but will be tough with oc703 to make it look good. You'll need to bevel and then finish the edged with some sort of resin to give it a hard edge.
You're best bet is probably just avoiding treatment within 3-4 inches of the speakers.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Acoustics for Musicians Bob_99 Home Audio Acoustics 4 09-07-07 09:26 AM
Boston Acoustics lcaillo Manufacturer and Vendor Reference Information 0 05-30-07 07:24 AM
GIK Acoustics lcaillo Manufacturer and Vendor Reference Information 0 05-18-07 09:28 PM
Stealth Acoustics lcaillo Manufacturer and Vendor Reference Information 0 05-04-07 08:43 PM
Need some help with room acoustics Tobias Home Audio Acoustics 7 04-26-07 12:13 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
