Acoustics Help! - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Acoustics Help!
Discuss Acoustics Help! in the Home Theater Installation and Systems forum; Acoustics Help! Hello,I've recently finished my basement and built myself my first Home Theater. I have since been to a Barrett's Home ...
GIK Acoustics
Old 01-04-08, 01:43 AM   #1 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
Acoustics Help!
Hello,I've recently finished my basement and built myself my first Home Theater. I have since been to a Barrett's Home Theater store and sat in a very well built room. Now I'm interested in adding acoustic sound treatments to my theater but have no idea what I'm doing or where to start. Can anyone help?Jon
Old 01-04-08, 03:54 AM   #2 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
Re: Acoustics Help!
First, welcome to the Shack Jon! You found a very good place to gather information and get some help
When it comes to acoustic sound treatments, you should take a look at the different forums, read some threads and try to gather some information first.
Use the search function to search for specific topics or products.
For instance, the Home Audio Acoustics section contains lots of useful information.
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
Old 01-04-08, 06:03 AM   #3 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
Welcome Jon.
If you'd care to post a description of the space and eventually as sketch (I think you need a certain amount of posts to be allowed), we'd be happy to take a look and make some recommendations.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 01-04-08, 02:55 PM   #4 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
Re: Acoustics Help!
Hello Bryan,
My theater is 10' 5 1/2" wide x 27' long. There is a soffit that runs along the ceiling on the left hand wall from screen wall to rear wall. Also on this wall is a bump out that is 1' x 1' 5 1/2" x 1' ( from the screen wall to the start of this bump out is 18' 3" ). Just past this bump out where the wall continues my audio video cabinet is built into the wall which measures 6' 6" tall x 2' wide x 18" deep. Hopefully this will help.
I will try to get pics if needed.
Thanks again: Jon
Old 01-04-08, 03:21 PM   #5 (Link)
Alias: Ethan Winer
Loc: New Milford, CT, USA
Ethan Winer's Avatar
User: #1679
Ethan Winer is offline
Lightbulb Re: Acoustics Help!
HT Crazy wrote: View Post
Not sure how deeply you want to get into this. If your intent is to DIY you'll need to read up and ask a lot of questions. If your plan is to buy treatment, a good vendor will tell you exactly what to do with no pain on your part. Either way, my non-commercial Acoustics FAQ explains the basics in detail.
--Ethan
RealTraps
Old 01-05-08, 01:04 AM   #6 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
Re: Acoustics Help!
Ethan,
Thank you for the link to your Acoustics FAQ. That is a lot of info to absorb at once but I'll just have to dive in
Jon
Old 01-05-08, 03:42 AM   #7 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
Re: Acoustics Help!
Ethan Winer wrote: View Post
Do you know ruffly what kind of price difference someone should expect between DIY and professional help? Is it like 1:2, 1:4 ?
Old 01-05-08, 07:33 AM   #8 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
Are you asking for price difference on the materials or on a professional to design a solution for you?
Bryan
Bryan Pape
GIK Acoustics
Old 01-05-08, 07:46 AM   #9 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
Re: Acoustics Help!
I am just wondering what the price difference can be between:
1) Purchasing and mounting everything alone
2) Paying a professional to find a solution. That's what I understand by a good vendor will tell you exactly what to do with no pain on your part.
I understand that there could be a significant price difference on materials but let's assume that the materials are quite similar in both cases (I assume that everybody is able to find prices for different DIY and proff materials in different shops and on web sites).
Old 01-05-08, 08:15 AM   #10 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
Well, then if the price of the materials is similar, as Ethan said, a good vendor will tell you exactly what to buy and where to put it. You'll be doing the mounting yourself in either case if I understand your posit correctily.
Hiring someone else to do the physical hanging can be quite expensive depending on who you contract with and what area you're in. If you're at all handy, hanging yourself is not a major task with most treatments.
Bryan
Bryan Pape
GIK Acoustics
Old 01-05-08, 11:14 AM   #11 (Link)
Alias: Ethan Winer
User: #1679
bpape wrote: View Post
Exactly.
RealTraps
Old 01-05-08, 11:33 AM   #12 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
Re: Acoustics Help!
Well, I'm kind of in the middle here. I don't mind DIY since I finished my basement myself, so handy work is no problem. I would also like a professional to guide me with locations of placing the treatments because I have no sound meters or the knowledge to do it.
I'm definitely thinking about using Owens-Corning 703 and 705 after reading Ethan's FAQ. I will take some pics this weekend after football is over with so everyone can get a visual and maybe give me some ideas.
Old 01-06-08, 09:40 AM   #13 (Link)
Alias: marcus
Loc: Houston, tx
User: #7534
Since: Mar 2007
udaman is offline
Re: Acoustics Help!
Welcom to the Shack Jon. Also, give dimensions of the room, electronic/speaker layout, and seating arrangements.
You got the two gurus, Bryan and Ethan, helping you out. It doesn't getting any better than that.
-marcus
Old 01-06-08, 10:21 AM   #14 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
You can get a lot of free help here if you can post some info about the room.
You're coming at this from 2 different directions though. On one hand, you want a vendor to tell you exactly what you need and where to put it. On the other hand, you're not buying anything but raw materials from a vendor (who most likely isn't an acoustician but more likely an HVAC guy).
Not trying to be difficult but just making clear the situation your posing. I don't mind at all with some general information to help folks out - I do it all the time. Just understand that most good acoustical vendors are very busy doing layouts for customers who are buying their products.
Bryan
Bryan Pape
GIK Acoustics
Old 01-06-08, 10:19 PM   #15 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
Re: Acoustics Help!
Here are some pics of the room.
Again the room is 10.5' wide x 27' long. The front row is twelve feet from the screen and the back of the second row is 7' from the rear speakers. The side speakers are in line with the first row.
The in-wall speakers are Niles Audio HD6 x 7 with two Velodyne DPS-10's ( one sub is near the lower left corner of the screen and the other is near the right rear speaker ).
Old 01-07-08, 06:15 AM   #16 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
Front corners are not large enough for effective bass absorbers, use the 2 rear corners for this.
Kill the front wall completely - 100% coverage in 2" absorbtion (due to long length to width ratio and very limited options for bass control).
Side walls will need at least 3 2'x4'x2" reflection panels on each side wall - potentially more depending on how the reflections fall.
Back wall - Personally, I'd do some 2" material with an FSK facing on it and cover 100% with cloth. Again, this is providing more bass control without overdoing the highs.
Bryan
Bryan Pape
GIK Acoustics
Old 01-07-08, 10:54 AM   #17 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
Re: Acoustics Help!
Hey Bryan, are you suggesting the front wall getting 100% coverage by custom cutting the matterial around the screen, speakers ....etc?
What type of material would you use Owens-Corning 703, 705 or both/something else?
Are you saying to cover only the back wall treatments in cloth?
Jon
Old 01-07-08, 11:14 AM   #18 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
Yes - if you're going to DIY. OC703 will work fine.
On the back, you're also covering the entire wall instead of just making panels - easier to just do big cloth 'grilles' if you're going to DIY.
Bryan
Bryan Pape
GIK Acoustics
Old 01-07-08, 01:02 PM   #19 (Link)
New Member
Alias: Jon
Loc: Illinois
User: #15066
Since: Jan 2008
HT Crazy is offline
Re: Acoustics Help!
OK, so the front and rear walls should be completely covered. What about bass traps in the corners of the rear wall or does the whole wall take care of this? How many of the OC 703 should I buy with FSK facing on it?
Old 01-07-08, 01:07 PM   #20 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
No need in the corners. Make the back wall 2" thick. Figure the square footage of your wall, subtract the door, and divide by 8 (8 sq ft per 2'x4'x2" pc of OC703). That's how many pcs you need.
Bryan
Bryan Pape
GIK Acoustics
Old 01-08-08, 01:48 AM   #21 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
Re: Acoustics Help!
Bryan: I read in some guidelines for acoustic treatment somewhere that one should never treat opposite surfaces (floor and roof, left and right wall etc) with the same absorbing material to avoid killing too many reflections.
Is it incorrect?
Could you explain us quickly how you chose to treat this room? Sorry if it's a stupid question, I'm learning...
Old 01-08-08, 06:33 AM   #22 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
That little tidbit is untrue. Now, in a live room in a studio where you want more reflection control with minimal material, you dont' mount opposite each other - but that's a matter of efficiency and economy.
As for the room, not sure what else to explain. I've laid out what needs to be done on every surface.
Bryan
Bryan Pape
GIK Acoustics
Old 01-08-08, 10:26 AM   #23 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Re: Acoustics Help!
Shouldn't he do 2" buildouts around the front/rear speakers so the face of the in-walls is flush with the treatment, not behind it? Also, wouldn't placing the front/back insulation over 2 inch furring strips giving it 2" of airspace and more effective bass trapping (4" buildouts around the inwalls)?
Edit: Oh, and while your at it, if you do a buildout for your front center, you should move it as close as you can to the bottom of your screen, and angle it upwards if your tweeters aren't "aim-able".
Old 01-08-08, 10:40 AM   #24 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Re: Acoustics Help!
Yes - the speaker should end up flush with the treatment.
Bryan
Bryan Pape
GIK Acoustics
Old 01-08-08, 02:36 PM   #25 (Link)
New Member
Alias: Jon
Loc:
