| Home Audio Acoustics 50hz null............SuggestionsDiscuss 50hz null............Suggestions in the Home Theater Installation and Systems forum; 50hz null............Suggestions So below is where I am at with no room treatment (to speak of anyway). This is stereo dipole speakers ... |
| | #1 (Link) | |||
| 50hz null............Suggestions So below is where I am at with no room treatment (to speak of anyway). This is stereo dipole speakers (Carver Platinums) with no sub and no intention of adding one. I've got a null centered at 50hz and this is as good as it gets with speaker placement and combination of open/closing doors/closets. Will corner traps help this? Last edited by bigbang; 01-06-08 at 12:53 PM. | |||
| | #3 (Link) | |||
| Re: 50hz null............Suggestions The one between 40 and 60 is the most noticeable though. Very noticable actually. I thought the rest looked and sounded fairly good considering there is currently no treatment. Am I missing something? | |||
| | #4 (Link) | |||
| Re: 50hz null............Suggestions You're missing decay time. It's not just frequency response. Also, you made no mention of having tried shifting seating position. The null could easily be seating position related. Bryan | |||
| | #5 (Link) | |||
| Re: 50hz null............Suggestions It's prevailent throughout the room with the exception of one corner of the rear/listening side of the room. What should I be shooting for for decay times ie what's realistic? Sorry for the noob questions and thanks for the replies. | |||
| | #6 (Link) | |||
| Re: 50hz null............Suggestions What sort of receiver/preamp are yo using? do you have an external amp powering your mains if so an EQ would do wonders. EDIT: Have you tried moving your main speakers out from the wall or closer to the wall behind them? Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #7 (Link) | |||
| Re: 50hz null............Suggestions I'm running a pre in to mono amps for each speaker. How can an eq help in solving my null? Is my graph that bad? I've done a search to compare and don't really see much. What I do see looks worse as far as fr goes and on the waterfalls the decay times usually arent on the graph. What is an acceptable time to reach the 60db mark and just how even throughout the bandwith can be expected and/or acceptable? | |||
| | #9 (Link) | ||||
| Re: 50hz null............Suggestions An EQ will boost the missing or low frequencies given that its only one area thats bad a simple 9band EQ will easily do the job but a 1/3 octave two channel EQ would be the best. Used they can be found on ebay for cheep. Quote:
Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | ||||
| | #11 (Link) | |||
| Re: 50hz null............Suggestions Home theater: Onkyo TXSR805 receiver, Samson Servo 4120 bridged @240wattsX2, 2-Mission 765 Mains, 4-762i's Rears, SVS PB13 Ultra, AR center PSC25, 2 Audio control C131 EQ's Toshiba HD A2 & Samsung BDP1400 DVD players, Sanyo Z2 projector Two Channel system: Yamaha RX-V995, Mission 764i's, & A/D/S MS3u sub Yamaha KX-393 Tape deck, CDC 805 5 disc CD changer, LG DV7832NXC DVD player, Motorola HD-PVR, Sony KP-53HS30 rear projection HDTV, turntable PS-T20 Nintendo Wii | |||
| | #12 (Link) | |||
| Re: 50hz null............Suggestions For EQ, I wouldn't have anything but a parametric. Even a 1/12th or 1/24th octave is a guessing game to try to get lucky and match what you need to their band centers - not to mention Q. If the null is all around the room, answer me this. Is it all through the room standing up or sitting down or both? If it's everywhere in the room, it's almost got to be something in the setup. Quite honestly, looking at your graphs, the FR is actually pretty good. You're within about a total of 5db up to 100Hz except for a small bump about 38Hz. Realistically, if you can get +/-4db in a room - especially without a sub - you're doing very well. I personally wouldn't mess with it. Target decay time will depend on the room size. Bryan | |||
| | #13 (Link) | |||
| Re: 50hz null............Suggestions Least amount of null is in between speakers. Bad on one side and worse on the other. I'm pretty sure it's just the room. I'd never consider anything but a PEQ for something like this, but only after room treatment. I'm thinking a panel type across the corners to start with. I'm already in good shape above 300hz. Am I on the right track? Does filling in the corner behind the panel help/hurt low end absorbtion? Typical decay for 200hz and below in a 16x17x8 would be? Thanks again for all the input! | |||
| | #14 (Link) | |||
| Re: 50hz null............Suggestions Corners are always a good first choice. In a room like that for 2 channel, I'd be looking around .35 in the midband, slightly lower at the top, that or slightly longer in the bottom. Now, those numbers are for RT60 (60db drop) Your graph from the average level is not quite 50db Bryan | |||
| | #16 (Link) | |||
| Re: 50hz null............Suggestions Sealed wooden membrane absorbers can also be used to good effect and are a bit more broadband and not so particular as to placement. In either case (membrane or Helmholz) you'll need a decent amount of square footage of them to make a good difference as they're not nearly as efficient per square foot as other types of absorbers. Bryan | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| My graphs - suggestions? | quenthal | REW Forum | 9 | 12-15-07 05:24 PM |
| suggestions? | tonyvdb | Care Chapel | 15 | 10-12-07 06:48 PM |
| Nasty Room Null: What to do? | covermye | DIY Subwoofers | 5 | 09-22-07 08:19 AM |
| Suggestions New Sub | srsmith | SVSound | 6 | 09-07-07 09:09 AM |
| Natural Null | Bob_99 | Home Audio Acoustics | 4 | 06-01-07 01:00 PM |
