Panel thickness for dealing with SBIR . - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Panel thickness for dealing with SBIR . in the Home Theater Installation and Systems forum; Panel thickness for dealing with SBIR . For cosmetic reasons Im looking to build some wall mounted panels to replace the free standing ones that I now ...
GIK Acoustics
Old 01-19-08, 10:40 PM   #1 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
For cosmetic reasons Im looking to build some wall mounted panels to replace the free standing ones that I now have behind my main speakers.I have a couple questions that I hope Brian or someone could help me with.The the front baffle of the speakers are 30" out from the wall and their is no possibility of moving them farther out into the room.
1)I suspect spacing is one factor but how else does one determine the required thickness of a panel for placement behind the speakers?
2) or should you just build one as thick as possible so that it is effective at lower frequencies?
3)how much wall area should be covered above and to the sides?(when looking at the panels from in front of the speakers)
Thanks in advance for your reply.
Fred
Old 01-19-08, 11:03 PM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: Panel thickness for dealing with SBIR .
What does your FR look like without the panels behind the speakers and where do you have them crossed over at? Those 2 things will determine if you should build 1, 2, or 4" panels.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 01-19-08, 11:10 PM   #3 (Link)
Alias: Fred
Loc: Canada
User: #1415
F1 fan is offline
Thanks Brian for the quick reply,at present I have no FR plots and they crossover to a sub at 60hz.
Old 01-29-08, 06:27 AM   #4 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
Any news on this?
I'm thinking I'll put my corner traps in the corners, floor to ceiling, and 4" panels at front and side wall right up against the corner traps. That way I can 'hide' the fact my traps are pulled 4" out from the actual wall as well. Will that work or will it over-dampen the front? This is for music, by the way.
My DIY build Status: Almost done.
My room thread
Old 01-29-08, 07:56 AM   #5 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Again, it would depend on how close the speakers are to the wall, if you have a sub, if so, where is it crossed over, and what your frequency response looks like.
You'd probably be OK with 4" directly behind. How close are they to the walls on the side?
Bryan
Bryan Pape
GIK Acoustics
Old 01-29-08, 09:48 AM   #6 (Link)
Alias: Maverick
User: #7168
Since: Mar 2007
The rear of the speakers are around 40cm from the wall, and the side of the speaker is maybe 30cm from the wall. Too close, I know, but it works....
My room thread
Old 01-29-08, 11:57 AM   #7 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
Yes - very close. I'd use 4" on the wall behind and 2" on the wall beside.
Bryan
Bryan Pape
GIK Acoustics
Old 01-29-08, 11:59 AM   #8 (Link)
Alias: Maverick
User: #7168
Since: Mar 2007
BTW, they are crossed over at 80Hz, and I have an SVS PB12+/2 doing the low stuff. The speakers are Dali Euphonia MS4, if that should matter.
My room thread
Old 01-29-08, 12:18 PM   #9 (Link)
GIK Acoustics
Alias: Bryan Pape
User: #2579
Since: Sep 2006
bpape is offline
And that's a good thing. My recommendations still stand. If you have good frequency balance between the mains and the sub, then all the more reason NOT to absorb too much below 80hz (4") that might actually 'unhide' a problem that's taking care of itself and just concentrate on what's being done by those speakers.
Bryan
Bryan Pape
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Need feedback on my first panel chas Home Audio Acoustics 12 10-24-07 10:33 AM
Chief Automated Flat-Panel Speaker Panel ACGREEN Video Displays and Processors 0 08-07-07 02:41 PM
Why mechanics love dealing with women Wayne A. Pflughaupt Chat Box 4 07-06-07 07:23 PM
Sonotube thickness? davepete DIY Subwoofers - Sealed and Ported 2 12-21-06 11:42 PM
General Acoustic Terms - SBIR bpape Home Audio Acoustics 0 09-20-06 08:58 AM
Mach 5 Audio
