| Home Audio Acoustics Basstraps not effective?Discuss Basstraps not effective? in the Home Theater Installation and Systems forum; Basstraps not effective? Hello.
I've been playing around with REW and my basstraps today, to measure the effect.
Well, set up REW, took ... |
| | #1 (Link) | |||
| Basstraps not effective? Hello. I've been playing around with REW and my basstraps today, to measure the effect. Well, set up REW, took a few readings of the room as it is now (1M, 8sweeps), and then removed all the acoustics panels I have. That is one corner trap (60cm face, 85cm tall, one 2'x4'x4" sheet cut in 8), two 4" sheets straddling corners, four 1,5" panels in reflection points and one 1,5" panel straddlign the last corner. Took a few more sweeps (1M, 8 sweeps again), and overlayed the plots. And they were virtually identical. There was minute differences, most likely due to inaccuracies in the measuring chain, but really minute. I was expecting a dB here and there, at least. So I started moving things around, placing traps at odd locations, floor to wall corners, opposite corners, basically wherever I could get to. And on a few of the measurements there were slight differences, some in the 0.5dB region, but very little. Are 4" Rockwool THAT ineffective? The thinner panels that I've used to kill reflections really help, my impulse response tell me that, but the basstraps are really just a waste. Do I just need more? I would think even the three thick panels I have would show up SOMEWHERE on my graphs? I have another 12 4" sheets on the way, and will make proper tri-traps from them, but I'm having second thoughts now. Might just dress them up and use them as general absorbtion, if they are not gonna do anything to my messed up bassresponse. | |||
| | #2 (Link) | |||
| Re: Basstraps not effective? Well, you're getting about 20% of the corner area. That will be helping in the decay times - have you looked at the differences in the waterfalls? Also, it may well be that a large part of your issues are either: - Nulls/peaks off the rear wall where you have nothing. - Height related - SBIR related (no panels directly behind the speakers - speaker and/or seating position related. Bryan | |||
| | #3 (Link) | |||
| Re: Basstraps not effective? I've had panels on the rear wall, the rear corners, floor to ceiling in front or rear corners (as much as I have panels for now). I've also had panels directly behind the speakers and in the 1st reflection off the front wall. Frequencyresponse was the same, and impulse response was the same. I have a strong reflection coming off the ceiling (of course) and another pretty strong reflection off something else that I just can't figure out. After 7ms there's a nice clear peak off both speakers. I thought it was the rear wall reflection, but putting panels up didn't help at all. What do you mean about height related and what is SBIR? Even if some of my problems are seating related (70Hz comes to mind), I would have thought at least SOME part of my curve would be affected by treatments? | |||
| | #4 (Link) | |||
| Re: Basstraps not effective? Some says that corners and near walls are worst place to put wool as acustic treatment. Wool will damp air movement, but sounds energy is mostly in form of pressure near the walls. Best place for wool to be effective is in the middle of two walls that are causing standing wave. However that is mostly effective against that single standing wave. Basstrap that is airtight everywhere else exept for air movement through wool might be effective in place where sound energy is in form of changing pressure. I did lowered roof of my concrete HT. 100mm wool with 100mm air gap in the middle of room and up to 350mm air gap at sides. Wool isn't always decreasing sound pressure, even on high frequencys. Heres some measurements of my room. Mic was on listening point, both speakers and sub on. Red line is without any part of the roof, green is with 100mm airgap roof in place (75% of area of roof) and blue is full roof in place. ![]() Effects are visible, but not easy to understand. | |||
| | #5 (Link) | |||
| Re: Basstraps not effective? Exactly. I'm gonna make my traps so I get 90% corner coverage and see what happens then. If I don't see anything then I'm sending the bill for the panels to Bryan.. I'm sure I'll se SOMETHING, then. If not, well.. It's a lesson learned.I was under the impression seating-related problems could be remedied or at least reduced with traps and treatments, but Bryan's post seems to suggest otherwise... | |||
| | #6 (Link) | |||
| Re: Basstraps not effective? Sorry - you can 'trap' till you're blue in the face but if you're sitting in a 20db null, many times you just can't treat it - you have to move. Things like sitting against a wall you're not going to 'fix'. You've tried a lot of the things that need to be done but not enough in any combination at any single time. Things all work together. SBIR is a ragged frequency response in the bottom end based on the proximity of the speakers to the wall behind them and the wall beside them. Quite honestly, my advice to you is to stop and remove all treatment from the room. Take a measurement (frequency, impules, and decay). Play with the seating position and learn where the issues are coming from and which are seating related. Fix what you can. Then, start playing with speaker/sub locations (actually 2 different steps - speakers first) and get that the best you can. Again, learn what's happening when you move things. Then go back and tweak seating position, then back and forth until you get the best you can. By that time, you should know what's speaker related, what's seating related, and what didn't change no matter what you did. THEN we can start looking at why they're happening and how to treat them. Sometimes in some rooms, you just can't fix everything. Things like usability, walkways, WAF, etc. simply won't let you do what needs to be done - so we do the best we can. Take your time and learn your room and setup before you do anything else. It'll pay off in the long run. Bryan | |||
| | #7 (Link) | |||
| Re: Basstraps not effective? I was afraid of that... ![]() My wife is gonna kill me.. ![]() That means moving the projector and screen... again... The ceilign is starting to look like swiss cheeze at this point... ![]() I'll spend the weekend making corner traps anyway, they can't hurt, I presume? Then I'll ditch the wife and kids, lock the door and measure and move stuff around until I know what's what. I'm sitting about 35% of the room length from the back wall (185cm in a 530cm room) right now, I would think that was about ideal? Have experimented very little with seating position, basically went for your recommendations on my room in another thread (dunno which one, it was one I started). I realize you can't know everything about my room, of course. I'm not blaming anyone for my difficult setup! ![]() I'll do measurements of the room, both dimensions and acoustic without any treatments, FR, IR and decay at different positions for speakers and listening positions first. I'll post them here for analysis, so I can learn what is the result of what. I have a bunch of 4" panels on the way, maybe I should NOT make traps until I know they are needed? Maybe I need more panels other than the corners instead? Then we can get to work on the subwoofer.... ![]() | |||
| | #8 (Link) | |||
| Re: Basstraps not effective? Seating doesn't sound like it's in a bad place. Try going forward just a little bit. Also, maybe consider moving off center maybe 6" or so side to side. Why do you have to move the screen and PJ. We're talking small movements here. Moving forward should not cause you to move anything but the seating. Speaker movement is not a big deal unless they're in-walls and then you're kind of stuck. Again, decay time is IMO as or more important than frequency response. Overly long decay times in the bottom end can cause dialog intelligibility issues, masked high end, tubby/muddy perception of bottom end, masking of extreme bottom end, etc. Lastly, be realistic. If you can get a treated, un-EQ'd room to +/-5db, you're doing well. Bryan | |||
| | #9 (Link) | |||
| Re: Basstraps not effective? I am off center in the room. My sweetspot is 160cm from my closest side wall, in my 390cm wide room. Going much closer to the speakers/screen will bring the screen in too close, really. I have a 40" tv behind the screen, so I can't readily move it any further against the front wall either I have measured the room with all treatments removed, including the 1st reflection panels. It sounds really hollow now, so at least it's doing some good up high. ![]() I will post measurements shortly. Not sure what you need, exactly. I have saved the measurements, so I can basically give you whatever REW can generate. Last edited by atledreier; 01-16-08 at 09:59 AM. | |||
| | #10 (Link) | |||
| Re: Basstraps not effective? Ok, these are fronts full range, no sub, from my current sweetspot 185cm from rear wall (room 530cm) 160cm from closest side wall (room 390cm) The speakers are placed symmetrical on the 160cm listening axis, if that made sense. The impulse response for the left speaker (and also seen in the plot for both speakers) look strange to me. Is this a measuring anomaly or some explainable phenomena? Fullrange frequency response, both speakers, 1/3octave smoothing ![]() 15-200Hz plot of both, left and right speaker ![]() Decay left ![]() Decay right ![]() Waterfall left ![]() Waterfall right ![]() Impulse left ![]() Impulse right ![]() | |||
| | #11 (Link) | |||
| Re: Basstraps not effective? Ok, I've been playing around wirh positioning again, and think I've found a better place for speakers and listening position. Moved the speakers forward, narrower and symmetric, and moved the seat back a little. Haven't really listened to it much, and haven't touched the subwoofer yet, but the fronts are looking better now. NB! This goes to 500Hz, and the target is for bass limited, not full range as measured. ![]() | |||
| | #12 (Link) | |||
| Re: Basstraps not effective? Played some more with my setup. Moved the sub around and found a good spot around midway on the side wall, that's about level with my listening position. EQ'd it, integrated it (pretty easy, it was pretty much flat FR, as were the fronts), and sat down and had a good listen. It sound like ****. Well, not as bad, but before I have had a sound that just keep you coming back for more. I often spend far more time than I really have on music. Last night I just didn't feel like it. The subwoofer is easy to locate, being out on the side. I tried lowering cutoff to 60Hz. That helped a little. Then I activated the sub's internal crossover on top of the pre/pro crossover and realigned phase and distance. Again, better, but I don't know how much distortion I introduced with the dual crossovers. Probably a lot. My system measure within +-5dB pretty much across the board, but it just sounds a little nagging. Maybe I need a house curve. I'm afraid more subwoofer level will just bring out the localization issues even more, though.. I need to experiment more, I think... | |||
| | #13 (Link) | ||||
| Re: Basstraps not effective? Quote:
Even if you now have a frequency curve that you like, the decay measurements may still be incorrect? Remember what Bryan wrote: Again, decay time is IMO as or more important than frequency response. Overly long decay times in the bottom end can cause dialog intelligibility issues, masked high end, tubby/muddy perception of bottom end, masking of extreme bottom end, etc. Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Sony PS3 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | ||||
| | #14 (Link) | |||
| Re: Basstraps not effective? Yes, I did, and my decay looks better than it did before I moved stuff around. The treatments seemed to work now too, with clearly visible effects bot in FR and decay. I have not applied a house curve this time around, but aimed for a linear frequency response. I have a slight increase towards the bottom end (+5dB at 15Hz) but nowhere near as aggressive as I did before. That could be it. I need to experiment more. Any tips on that subwoofer localization issue? | |||
| | #15 (Link) | |||
| Re: Basstraps not effective? Where is your xover frequency? From your original plots, it appears that you're running the mains full range - or was that just for measurement purposes? Your mains should be cut off at 80Hz and the sub brought in at 80Hz. If you have mains and sub trying to all 3 do 80Hz down, they're fighting each other. Mains go where they need to for best locking to screen, imaging, FR from 80Hz up - which is rarely where they produce the smoothest bottom end response. Bryan | |||
| | #16 (Link) | |||
| Re: Basstraps not effective? I used fullrange for measurement purposes only. I usually cut at 80Hz, and have completely disregarded frequencies below that for the current placement. The sub initially was crossed over at 80Hz. With the sub off to one side now, crossing it over at 80Hz makes it very easy to locate, and is very distracting. Crossover at 60Hz help a little, but it is still localizable. I'll post plots when I get home, I'm currently at work. | |||
| | #17 (Link) | ||||
![]() Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Sony PS3 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | ||||
| | #19 (Link) | |||
| Re: Basstraps not effective? Some things to consider as you move through your odyssey... Look at the peak at 60hz in the frequency response combined. It's matched by a peak in decay time for each speaker independently. This means it's like either : - SBIR related due to distance from front wall - Seating position related Now, look at the big dip in frequency response at 120Hz. Do you see a big dip in either speaker by itself in decay time? I suspect you won't in frequency response runs either. This tells me that the interaction between the 2 speakers is causing this effect. Things like non-symmetry or even just spacing can do this but it's not seating related. Lastly, look at the drastic difference the starting trace of the decay time between left and right. They're completely different. That points absolutely to non-symmetry in the speaker setup. 80-100hz is hugely different and again, points to boundary interaction issues of left vs right. Any way you can post a sketch of the room so we can get a better idea of what's happening? Please include where things are in the room with dimensions if you can. Bryan | |||
| | #20 (Link) | |||
| Re: Basstraps not effective? Those initial measurements are pretty much void now, as I've moved everything around. I spent last night listening to music, trying to figure out what it was that I didn't like. I THINK it's the same thing that makes me not like Audyssey-corrected systems, probably the flat target. I am used to a +10dB hard knee curve a'la Wayne. Now I have a slight rise at the very bottom, but nothing like I used to. So I will try with a house curve and re-eq my sub. Regarding the localization issues with the sub, they were not (imo) as prominent last night as they were in my initial listening session. I have no idea why. Maybe I've gotten a little more used to it? I also adjusted phase on my subwoofer slightly (maybe 10degrees on the dial). No idea if that can have such a big impact. I am aware that having the sub off to one side like that is probably the worst place it can be in that regard, and it is also quite close to the primary listening position. I used to have the sub in a nearfield position, but centered in the room. This was great for non-locatability, but my FR brickwalled at 60Hz. I might have to sacrifice FR to make the sub blend in more, the current situation WILL bug me in the long run, I'm sure of it. Right now my fronts are placed (center of front baffle) 110cm from front wall and 95cm from the side walls. The subwoofer is on the right side wall, about 250cm from the front wall (Where do you measure a PB12+/2?). If you see the pictures in the thread linked further down this post it's located between the blue drape to the hallway and the white concrete chimney, where the bookscase was. Fit snugly against the wall there. My listening position in centered in the width of the room, about 120cm from the rear wall. The room is 530cm deep and 390cm wide, 230cm ceiling. Some more info on the room in another thread I started: here. That is the room as it was when the initial measurements were taken. Last edited by atledreier; 01-18-08 at 03:19 AM. | |||
