| Home Audio Acoustics does anyone know?Discuss does anyone know? in the Home Theater Installation and Systems forum; does anyone know? i've got all the first reflections covered with panels but i'm running 7.1 system and i was wondering about the ... |
| | #1 (Link) | |||
| does anyone know? i've got all the first reflections covered with panels but i'm running 7.1 system and i was wondering about the reflections for the surround speakers. dont they need panels for their reflections? | |||
| | #2 (Link) | ||||
| Re: does anyone know? Quote:
Since only about 10% (fake number pulled out of my end) of the movie sound comes out of the surround channels, I wouldn't lose any sleep over it. One caveat, it probably would be good, if your surrounds are within 2-3 feet of a side wall, to treat that wall next to them with a small panel. It should help with speaker boundary interference response (SBIR). Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | ||||
| | #3 (Link) | |||
| My philosophy is to absorb first reflections for all speakers in a system. The problem with early reflections is they create a skewed frequency response known as comb filtering - a series of many peaks and deep nulls. If you don't want a badly skewed response for your mains, I can't see why you'd want that for the surrounds either. ![]() --Ethan RealTraps | |||
| | #5 (Link) | ||||
It has been shown through perceptual research that these first reflections actually increase enjoyment. Would you recommend treating anyways, if so why? | ||||
| | #6 (Link) | |||||
| Yes. Quote:
![]() It might be that in a very large room - and I'm talking 20 feet wide or wider - that side-wall reflections are less damaging than in a more typical size room. But generally speaking, small-room reflections are always best avoided IMO. Especially if the reflecting surfaces are closer than ten feet to your ears. BTW, this includes the rear wall behind you too. --Ethan RealTraps | |||||
| | #9 (Link) | ||||||
What kind of research is this? How was it done? Do you by any chance have the publication listing so I can read it? Quote:
There are various papers on these subjects. Floyd Toole has many regarding relating measurements to listener preference as well as room interaction. Some notable articles of his include (I will not be able to link these as they aren't posted online your local library would be your best bet): Listening Tests-Turning Opinion into Fact JAES Volume 30 Issue 6 pp. 431-445; June 1982 Subjective Measurements of Loudspeaker Sound Quality and Listener Performance JAES Volume 33 Issue 1/2 pp. 2-32; February 1985 Loudspeaker Measurements and Their Relationship to Listener Preferences: Part 1 JAES Volume 34 Issue 4 pp. 227-235; April 1986 Loudspeaker Measurements and Their Relationship to Listener Preferences: Part 2 JAES Volume 34 Issue 5 pp. 323-348; May 1986 The Modification of Timbre by Resonances: Perception and Measurement JAES Volume 36 Issue 3 pp. 122-142; March 1988 The Detection of Reflections in Typical Rooms JAES Volume 37 Issue 7/8 pp. 539-553; July 1989 Loudspeakers and Rooms for Sound Reproduction—A Scientific Review JAES Volume 54 Issue 6 pp. 451-476; June 2006 Well it looks like I have listed all of his articles. I guess this is because simply put he is the leading researcher involved with perception in relation to loud speakers. Also, if you look up Ian Paisley's research you will see that through thousands of blinded trials with thousands participants, that wider and smoother frequency responses were highly preferred in a controlled environment. | ||||||
| | #10 (Link) | ||||||
| Quote:
http://www.realtraps.com/rfz.htm Figures 1 and 2 tell all. This is in addition to many listening tests. Do me a favor? Please describe your own listening room and its acoustic treatment. If you can post a photo of the front of the room too all the better. Thanks. --Ethan RealTraps | ||||||
| | #11 (Link) | ||||||
I fully understand the idea of comb filtering and the artifacts that occur from doing so, but the relevant credible research shows that in spite of this artifacts the slightly delayed reflections are desirable for stereophonic listening. Also, I am very well aware of the factors effecting imaging: Loudspeaker room interaction, symmetry of response with respect phase with response to listener position and lastly treble response. All these variables can be controlled with proper treatment and equalization even with first reflections left "live." This brings up another question with an omnipolar speaker would you treat the first rear to the speaker reflection? This is another situation that would cause even more comb filtering and has been proven through credible research to increase stereophonic listening pleasure. Quote:
It seems logical that application would change treatment needs after all. Quote:
My current room is not dedicated and laid out in an asymmetric way in which treatment of the first reflections is necessary. I am referring to an ideal circumstance far from my own. I do however have a friend with an extremely high quality omnipolar 2-channel system with axial and off-axis response near identical to each other. He personally conducted blinded studies with both musicians as well as other individuals with his results mimicking Toole's. Personally, I have gone into a Hi-Fi shop and played with such treatments in a subjective manner to the same effect as well. | ||||||
| | #12 (Link) | ||||
| Quote:
| | #13 (Link) | ||||
On another note I am not sure I understand how citing relevant research is inappropriate. In fact it is my understanding properly conducted peer reviewed research should be used and applied otherwise what is the point? Have a good day. -Andrew | ||||
| | #14 (Link) | |||
| Re: does anyone know? Early reflections from the main 3 speakers are definitely undesirable. In the rear, it's not AS critical since you want a non-localizable 'soundstage'. In multi-channel, we always treat the front and rear differently. We always kill the front wall completely but never kill the rear wall completely. This is not to say that there is not comb-filtering, there is. It's not to say that it doesn't have an impact on frequency response, it does. What it is, is a tradeoff. One can have no comb filtering for the rear by creating an RFZ for all of those too - but at the expense of the diffuse soundstage that is desirable. It's a lesser of 2 evils and most won't lose the soundfield envelopment and be able to pinpoint their surrounds to save a bit of frequency response abberations. If you stop and think about it, diffusion can cause some of the same issues due to out of time arrivals and some cancellations in the wells but the effect it gives is still more desirable than the flat wall. Same kind of trade off. And no, before someone jumps on me about diffusion and specular reflections being the same thing, they're not. They can just yield some of the same kinds of effects. It's all in what you're trying to accomplish. If I can let part of the room work for me instead of deadening even more of the mid and high frequencies, I'll do that. If we were to plot every reflection point for all 7 speakers for all seats in a room, almost every single surface in the room would be 90+ % covered with absorbtion. Then you've shot your balanced target decay time curve all to hell. Just my 2 cents. Bryan | |||
| | #15 (Link) | ||||
The difference between avaserfi's citations and your claims, though, is that it appears that yours are not from sources that have performed careful, scientifically valid experiments to come to their conclusions. You have every right to believe what you want. But the credible evidence available does not appear to support you. -Chris | ||||
| | #16 (Link) | ||||
| Quote:
I repeat this again - every professional designer of recording studios I know of agrees that first reflections are damaging and should be absorbed. --Ethan RealTraps | ||||
| | #17 (Link) | |||
| More thoughts on this: There are educated listeners and uneducated listeners. Often I hear from what I consider uneducated listeners that they prefer the sound of their room rather than a treated room. To me this is related to the conventional wisdom that a 2-channel room should be more live sounding than a home theater. I happen to disagree with that - most movies have music, and that music should sound as the mix engineers intended. If absorption in a home theater improves imaging, then it does the same for a 2-channel setup. So I guess you could say a well-treated room can be an acquired taste. In my experience small room ambience is always bad ambience. Versus a room large enough to have true reverb. But then we're outside the realm of home listening environments. I work with many professional recording and mastering engineers, and I consider them to be educated listeners. These people listen to music for a living, and if they can't hear clearly how the music really sounds, without being influenced by the sound of their own room, they can't do their job. From my perspective, the listener at home should aim to hear the same quality as the engineer heard when mixing. And that means not leaving early reflections untreated. Of course, there's no accounting for taste, and it's not my job to tell someone what they should or should not prefer and enjoy. All I can do is address the science of audio, and from that perspective it's clear (to me, anyway) that comb filtering due to early refections is best avoided. --Ethan RealTraps | |||
| | #18 (Link) | |||
| Re: does anyone know? Ethan. Not to get into a tiff, but some real questions. - How many of those guys mix multi-channel? - How many of the mixing rooms have 90% of their wall surface covered in broadband absorbtion (which is what it would take to catch all the reflections from all of the speakers to all of the seats in a home theater)? And sorry, but I'll disagree that a 2 channel room and a multi-channel room should be treated the same. In multi-channel, I have independent speakers to reproduce the diffuerent aural cues of the space. In a 2 channel system, you don't and you HAVE to count on the room to help you a little bit. Have you ever listened to a good 2 channel recording outside? If it's anything that has 'space' to it like an orchestral piece or a choral piece recorded in a hall or church, it'll sound awful. It sounds thin and uninvolving. Now, if you listen to the 'in the box' over produced, electronic stuff that HAS no 'space' to it, then it'll sound about the same. Guess that's up to 4 cents now ![]() Bryan | |||
| | #19 (Link) | ||||
-Chris | ||||
