Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Corner trap depth vs efficiency
Discuss Corner trap depth vs efficiency in the Home Theater Installation and Systems forum; Corner trap depth vs efficiency No problem at all. It's not a simple thing. There are a TON of variables involved. If you'd like to ...
GIK Acoustics
Views: 1093 - Replies: 25
Old 06-23-09, 07:40 PM   #26
Design and Acoustics Moderator
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
  bpape is offline
Re: Corner trap depth vs efficiency
No problem at all. It's not a simple thing. There are a TON of variables involved. If you'd like to give a little more info:
- room dims
- what it's used for
- how many people
- how many and what kind of seats
- how the room is built
I can take a WAG at it. A sketch would be a ton of help too.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
