Proper installation for sound absorption question... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss Proper installation for sound absorption question... in the Home Theater Installation and Systems forum; Proper installation for sound absorption question... Hi I have a Auralex Sonosuede kit (8 acoustic panels, and 4 Bass trap panels ) setup in my dedicated ...
GIK Acoustics
Old 02-02-08, 09:08 AM   #1 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is offline
Hi I have a Auralex Sonosuede kit (8 acoustic panels, and 4 Bass trap panels ) setup in my dedicated home theater room, which is roughly 18 x 14 ft. My question is, since I set up the panels myself should some of my high frequency panels on the wall be offset from the wall with spacers? And secondly, should the bass trap panels in the corner be fastened in there tight? As it stands the bass panels are just sort of sitting there.
Anyone with experience with these panels or sound absorption in general, I would love to hear your opinion.
Thanks!
Old 02-03-08, 07:46 AM   #2 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
Re: Proper installation for sound absorption question...
Bass trap panels just sitting there is fine.
Spacing all you other panels 2" off the wall would be a good idea. The absorption of the auralex panels already falls off at hte low end. Spacing them out will help them absorb lower frequencies.
Old 02-03-08, 11:53 AM   #3 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is offline
Thanks Marshall, that is good to know. The one follow question to this I have for anyone (as I purchased the panels second hand, without the spacers) what could I use in place of the spacers. Perhaps something at Home Depot? Or anything "not" to use as spacers.
Thanks again.
Old 02-03-08, 12:28 PM   #4 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
Don't use anything that will rattle around back there, but other than that, anything will work. Those panels are pretty light, aren't they? You could use a couple small pieces of wood, pvc pipe...pretty much anything.
Old 02-03-08, 12:34 PM   #5 (Link)
Alias: George
Loc: Nova Scotia
User: #15981
Since: Jan 2008
Rambo4 is offline
Yeah there is no weight to them at all. So I will take a look in my garage for a few pieces of wood to use as spacers. I may stagger them as they are in pairs on the wall. One flush to the wall and one spaced out. The look should be ok as well. Shouldn't get me into to much trouble with my wife.
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Question on proper volume levels for testing ckaye99 REW Forum 3 12-21-07 01:10 PM
Mattress Sponge as sound insulation and absorption? skoch Home Audio Acoustics 14 11-10-07 01:09 PM
In wall component video installation question rkweekly Remotes | Cables | Accessories 10 08-03-07 03:03 PM
Sound blaster live 24 installation koiman REW Forum 4 04-11-07 03:15 PM
My First Post - Question On Absorption Coefficients.... LewisCobb Home Audio Acoustics 23 01-16-07 02:52 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
