non HT Q-- noisy neighbor in a townhouse - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Discuss non HT Q-- noisy neighbor in a townhouse in the Home Theater Installation and Systems forum; non HT Q-- noisy neighbor in a townhouse Okay, a question about sound proofing, not room treatments for acoustics. I live in an old townhouse, sadly not on ...
GIK Acoustics
Old 01-28-08, 09:38 AM   #1 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
I live in an old townhouse, sadly not on an end unit. Walls are supposed to be double 5/8" drywall on the common walls, separated by a 2x6 between houses. The unit next to me had a nasty flood and a lot of the drywall needed to be replaced -- I am not sure they replaced it with the correct thickness (or number of layers). But since I can't inspect or prove that . . .
The problem: two people have lived there and been pretty quiet because all I heard was an occasional alarm clock. the new guy, however likes to listen to his TV so loud that I could tell you what is on. He does respect 11 pm as a quiet time though. So the thought of soundproofing the room has come up again.
It's a narrow room, so I want to minimize any intrusion on the long wall (less than 1"). I don't think I could insulate between the houses without a permit or a lot of hassle, so I'm looking at mostly add-on options to the existing wall.
So far, here are my ideas:
Quietrock layer atop the already double layer. I only need 3 sheets and am pretty good and mudding and taping drywall. Cost: $150 or so + crown molding.
Plain layer of drywall. Cheaper, but I'm not sure if it will help.
Giant acoustic panels on every wall. Rock wool + nice fabric. Would probably look like the nice rooms from old Victorian houses. No idea on cost
Finally, localize the absorption and make an acoustic headboard. Right now we have none and were planning on a plywood/foam/cloth one. I figured, why not try a frame/rock wool/cloth version instead. At least it would absorb the sound closest to our ears.
Any other ideas or comments? So far, the wife is on board with any of these.
Thanks.
Old 01-28-08, 10:16 AM   #2 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Re: non HT Q-- noisy neighbor in a townhouse
If the wall isn't insulated, it won't help. Panels inside the room won't help no matter what in terms of isolation.
A layer of 5/8" with Green Glue between layers will help some - provided the wall is insulated. Worst case, you can poke a hole in each stud cavity and blow in insulation then patch.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 01-28-08, 11:27 AM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
I figure the added mass would have to help some in terms of attenuation, although probably not a complete isolation.
As far as the panels, if they were aimed "in reverse" wouldn't any wave being re-radiated from the existing wall have to pass through them and thus be attenuated?
I guess I'm missing something fundamental here.
Old 01-28-08, 01:12 PM   #4 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Bryan,
I've been reading up on Green Glue and it seems pretty impressive. I may just add 1/2" drywall with green glue and go that route.
you can PM me the answer, but do you sell the stuff and acoustic sealant? if so, I'm interested.
Thanks,
Anthony
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
Noisy subs Moez Home Audio Subwoofers 6 01-03-07 03:02 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
