Acoustic Panels? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Home Theater Installation and Systems > Home Audio Acoustics
Acoustic Panels?
Discuss Acoustic Panels? in the Home Theater Installation and Systems forum; Acoustic Panels? Does anyone know a good place to look for cheap acoustic paneling? Any opinion on these: http://cgi.ebay.com/Auralex-Wedgies-...QQcmdZViewItem...
GIK Acoustics
Old 03-15-08, 05:08 PM   #1 (Link)
Alias: BleedingStar
Loc: Las Vegas
User: #16356
Since: Feb 2008
BleedingStar is offline
Acoustic Panels?
2- 58" King Sound Prince Electrostat Loudspeakers
2- Infinity Audio PS210 Powered Subs to got with Electrostats
Jensen Center (soon to be replaced by: 1- Definitive Audio CLR2300 Center Channel
4- Technic SB-T100 (surrounds)
3- JL 10" Subs
Kenwood VR-6070 THX Receiver --- Denon AV600 ---- Technic SU-Z900
Acer XD1170 Projecter --- 120" Screen
Old 03-15-08, 05:14 PM   #2 (Link)
Alias: BleedingStar
Loc: Las Vegas
User: #16356
Since: Feb 2008
Re: Acoustic Panels?
How about this pack for starters?
http://cgi.ebay.com/Auralex-D36-Acou...QQcmdZViewItem
3- JL 10" Subs
Old 03-15-08, 06:04 PM   #3 (Link)
GIK Acoustics
Alias: Bryan Pape
Loc: Wildwood, MO (St. Louis)
User: #2579
Since: Sep 2006
bpape is offline
Foam is really not all that great. 703 is MUCH better for the same thickness. Also remember you'll need some thicker stuff in various places in the room to even out the curve or the room will be totally dead in the highs and the bass will still be out of control.
Bryan
Bryan Pape
Lead Acoustical Designer
GIK Acoustics
Old 03-15-08, 07:25 PM   #4 (Link)
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
tcarcio is online now
www.atsacoustics.com is about the most reasonably priced that I have seen short of making them yourself you can't get them much cheaper
Old 03-15-08, 07:48 PM   #5 (Link)
Alias: BleedingStar
Loc: Las Vegas
User: #16356
Since: Feb 2008
Yeah, those are pretty dang reasonable actually.
3- JL 10" Subs
Old 03-16-08, 09:28 AM   #6 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is offline
ATS is very reasonably priced, but they use Rockwool instead of 703. They perform almost identical, but the rockwool is flimsy needing a wood backing. With 703, you can leave the back open, and if you space it an inch or two off the wall, will get much more efficiency in the lower frequencies.
Look to get 703 and build your own if you are on a budget, or go with Realtraps or GIK.
Old 03-16-08, 12:34 PM   #7 (Link)
Alias: Ice10
User: #7962
Since: Apr 2007
Vaughan100 is offline
There is also www.readyacoustics.com. Very nice bags that you can fill with either 2", 4" or 6" fiberglass or rockwool.
--Regards,
« Home Theater Shack > Home Theater Installation and Systems > Home Audio Acoustics »
Similar Threads
acoustic panels and batting chas Home Audio Acoustics 6 08-13-08 06:14 AM
Acoustic panels finally hung... cruzmisl Home Audio Acoustics 4 08-13-07 08:56 AM
Which acoustic panels? cruzmisl Home Audio Acoustics 18 07-21-07 10:40 AM
Cats and Acoustic panels F1 fan Home Audio Acoustics 7 07-09-07 07:01 PM
DIY Acoustic Panels southworth Home Audio Acoustics 4 12-01-06 02:03 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
