| Home Audio Acoustics DIY looks betterDiscuss DIY looks better in the Home Theater Installation and Systems forum; DIY looks better I have bought some products from GIK and though I'm very happy with their performance, I have to say my ... |
| | #1 (Link) | |||
| DIY looks better I have bought some products from GIK and though I'm very happy with their performance, I have to say my DIY looks better. I think it's the same with other ones you buy from other companies as well. They really don't look that great unless they cost very much like ASC products. I've simply built a frame to fit rockwool acoustic panels (probably same as 703,705s or whatever you call them), and pulled a cheap fabric of cotton/linen from IKEA. Fabric after taste can of course be chosen and changed when one get bored of them. Marimekko has some nice ones, but they're expensive. The pictures are not that good, but they give an impression. I'll hang them up later. If anyone wonders why my speakers are placed on books like that, it's because they are temporarily front ones till my new babies arrive. | |||
| | #2 (Link) | |||
| Re: DIY looks better Very nice work, omholt! I think the key is that DIY has the potential to look better, but also could easily underperform or look aweful if not done with care. I like you custom fabric cover. Thanks for showing us what is possible! Mark Pearland, TX (Houston) | |||
| | #6 (Link) | |||
| Re: DIY looks better Humm, really nice. I'm right in the middle of adding treatment to my room, so I'll have to try that one! BTW: Where did you buy your GIK products in Norway? Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | |||
| | #7 (Link) | |||
| Re: DIY looks better I ordered them from GIK in the states. They ship worlwide. Shipping cost is quite high and then you have to pay 25% tax (moms) on top of everything, but it's still not that bad. DIY's are of course cheaper and you can pick your own fabric. | |||
| | #8 (Link) | |||
| Re: DIY looks better Probably already known but worth repeating, when covering panels for early reflections, do pay attention to the type of fabric being used so as not to minimize the absorption of the high frequencies. Bob "There is always hope, even if it is just a fool's hope." | |||
| | #10 (Link) | |||
| Re: DIY looks better It doesn't matter what kind of material you use as long as you are able to 'blow' air through it. For instance, thick materials or materials with a layer of plastic on the back are useless here. Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100" | |||
