| | #1 (Link) | |||
| How to treat large soffit? Hello In my Home theater there is a soffit that extends the length of the room at 25 ft on one side of the room and the width is 4 ft.Low frequencies cause some echo coming from the soffit and need some treatment. This is the main HVAC trunk. The soffitt has already been closed in and finished in drywall so my treatment options are limited to the surfaces in the room. I also have a door that opens into the room at one end of the soffitt where the top of the door is 2 inches below the soffitt so treatment thickness at one end will be an issue. Questions: Do I treat just the underside of soffit or the underside and depth (depth is 9 1/2 inches)of the soffitt as well? What type of treatment is recommended? How to finish around the door opening if the treatment is thicker than 2 inches? Other info: Room size- 25 ft long by 16 ft wide (the rear width is 12 ft) Room surface is 5/8 inch drywall including ceiling. Extra soffits could not be installed to balance the look of the room as there are 2 windows (front wall and sidewall). I have covered both with scrape pieces of drywall, vapour barrie and covered with panels for appearance. Thanks Dwight | |||
| | #2 (Link) | |||
| Re: How to treat large soffit? Nothing you're going to put on the outside (that's reasonable thickness) is going to fix this - sorry. My suspicion is that you're getting a resonance from since it's hollow and uninsulated. The best thing you can do is to try to lower the resonant frequency and try to make it less efficient. I'd try to put another layer of drywall on it. This will accomplish both. Bryan | |||
| | #3 (Link) | |||
| Re: How to treat large soffit? Thanks Bryan. My better half not agreeing to doubling up of the drywall. Can I treat the underside and depth over the majority of the soffitt in say 4 inch absorptive material except for the door area? Not sure what that would looK like but is that an option? | |||
| | #4 (Link) | |||
| Re: How to treat large soffit? It won't stop the ringing if that's what's happening. It will give you some broadband absorbtion but then you'll be out of symmetry left to right. It's a tradeoff. Bryan | |||
| | #5 (Link) | |||
| Re: How to treat large soffit? Would it help to blow in some insulation? That would only require a few smalls holes and a simple patch job. Listen to the Real HT Info Podcast at http://realht.info, or on iTunes. Also, listen right here on The Home Theater Shack. Just use the web applet on the front page. | |||
| | #6 (Link) | |||
| Re: How to treat large soffit? Absolutely if there's room for anything significant. However, he said that any destruction of the existing drywall wasn't doable so I disregarded any ideas of insulating inside - which is what should happen. Bryan | |||
| | #8 (Link) | |||
| Re: How to treat large soffit? If you know what frequencies are causing the problem then there is no reason absorption wouldn't work. If the problem is "boominess" from the soffit cavity or "ringing" of the plasterboard then that is a different issue which still may be solved with heavy absorption to the underside as this would provide some damping of the plasterboard. A few extra screws may also help reduce the reaction of the plasterboard. | |||
| | #10 (Link) | |||
| Re: How to treat large soffit? Seb The problem is boominess. Treating the underside with heavy absorption would help however there is a door opening into the room where the top of the door is 2 inches below the soffit. Applying absorption thicker then 2 inches will be problematic. | |||
| Thread Tools | |
Similar Threads | ||||
| Do you treat a room to increase bass | jwhite8086 | Home Audio Acoustics | 22 | 12-01-07 03:47 PM |
| First graphs, how to treat? | krister | REW Forum | 0 | 10-28-07 05:03 AM |
| Soffit Help | Bob_99 | Home Audio Acoustics | 12 | 02-13-07 04:37 PM |
| Why You Must Acoustically Treat Your Hi-Fi Room | geekwithfamily | Home Theater, Audio and Video News | 0 | 09-14-06 03:40 PM |
| Trick or treat? | rolyasm | Home Audio Acoustics | 1 | 08-01-06 09:50 AM |
