| Home Audio Speakers Noob (to this forum) in need of suggestions for 5.1 systemDiscuss Noob (to this forum) in need of suggestions for 5.1 system in the Manufactured Speakers and Subwoofers forum; Noob (to this forum) in need of suggestions for 5.1 system Okay, I'm moving into a house (been an apartment dweller for years). Currently, I'm using a Rocket Tyke system that ... |
Views: 550 - Replies: 10
| Noob (to this forum) in need of suggestions for 5.1 system Okay, I'm moving into a house (been an apartment dweller for years). Currently, I'm using a Rocket Tyke system that I bought from AV123 several years ago. The receiver is a Pioneer VSX-1017TXV (got a great price on it, it suits my needs for the time being, can't really afford to upgrade it for now). Room dimensions are 12x14x8 there are french doors that open to the foyer, but they can be closed during times when the volume will be loud. I'm planning on sticking with a 5.1 setup for now, with the option of expanding to 6 or 7.1 in the future. What I would like is a good system overall with a few basic musts . . . It MUST produce clear dialog and vocals at lower volumes (the Tykes need to be fairly loud believe it or not before they'll produce vocals that are unmuddied). It must provide decent LFE when played at volume, I wanna hear the lower end stuff I've been missing. The price must come in around $1,500 or less (preferably less) with stands or mounting options included. My first instinct is to go with a complete SVS SBS-01 set with a PB10-NSD sub (cost w/stands is $1,219. I'm also sorely tempted to go with AV123 again and go with the complete X-Series setup for $1,254 (in black, but I'd have to wait since they don't have it in stock until May for the main speakers). The drawback here is I've heard not-so-good things about the X-Sub as far as home theater goes. I'm open to any decent maker (Ascend, Aperion, etc.). Thanks for any help or ideas! Last edited by etawful; 04-08-08 at 08:57 AM.. Reason: Forgot to say thank you :) | ||||
| | #2 | ||||
| Re: Noob (to this forum) in need of suggestions for 5.1 system Welcome ET, your suggestions are fine. I own the SVS system and can assure you that no matter the volume level, you will hear clear dialog. Keep in mind, tho, that speaker placement, sound absorption, etc play a great part in the overall sound of any system. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #3 | ||||
| Re: Noob (to this forum) in need of suggestions for 5.1 system Well if its vocals to be the key I would go with Axiom Audio. You can get a very nice system for around the $1500 mark, especially if you go through their Factory Outlet. An M22, VP100, QS4s and EP350 sub for slightly more than your budget. I started out with this system and it is one of the cleanest sounding bookshelf systems I have heard. The sub is also pretty good plays almost on par with my SVS PB12-NSD. I know the price is higher than your budget and usually the budget goes out the door once you start looking to upgrade the system anyway. The M22s are wall mountable so no need for stands, just mounts which are a little cheaper. Axiom has a forum of their own and an audition list, check it out to see if anyone lives nearby to give you an audition. Other than that any of the brands you listed should serve you well. the wait for the X-series just might be worth it, from what I have heard. | ||||
| | #4 | |||||
| Re: Noob (to this forum) in need of suggestions for 5.1 system Quote:
Mounting the front speakers on a wall is always a bad idea due to the vibrations transfered through to the wall from the speaker causing undesirable results. The Main front speakers should always be at least a foot from any wall. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | |||||
| | #5 | ||||
| Re: Noob (to this forum) in need of suggestions for 5.1 system I own an SBS-01 system -- 4 SBS-01's in front along with SCS-01 and two SBS-01's in rear. Subwoofer is PB12-NSD. I bought mine in silver, all items on close out. Been very satisfied with this system which performs well on both HT and music. | ||||
| | #6 | |||||
I've never had problems with wall mounting mains, how would you explain the new inwall styles coming out all over the place, they still sound pretty good, IMO. I have my mains only about 3" out from the wall and they still sound great to me. I have moved them out from the wall just to see if anything changes, the bass drops a touch, but thats about it. Not everyone has the room or desires to(aesthetics) take a speaker out into a room 12" especially if it is a larger floor model. You have to make do with what you have and what else is going on in the room. | |||||
| | #7 | ||||||
Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||||
| | #9 | ||||
| Re: Noob (to this forum) in need of suggestions for 5.1 system Okay, there was finally some b-stock at SVS. I ordered SCS-01's for the front (right, left and center) and SBS-01 for the surround. The SCS were b-stock, so total price was only about $10 more than it would have been for a new/a-stock 5.0 set of SBS-01s So my final setup will be the Outlaw LFM-1 Compact with this SVS setup . | ||||
| | #10 | ||||
| Re: Noob (to this forum) in need of suggestions for 5.1 system you will love your system. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
