| Home Audio Speakers Newbie need advice/suggestion for 1st HTDiscuss Newbie need advice/suggestion for 1st HT in the Manufactured Speakers and Subwoofers forum; Newbie need advice/suggestion for 1st HT Ok, I am new to this, but know that I want something better than a
HTIB. However, I don't want ... |
Views: 465 - Replies: 4
| Newbie need advice/suggestion for 1st HT Ok, I am new to this, but know that I want something better than a HTIB. However, I don't want to drop thousands on a new home theater. The room is 25x15 with to large enterances to the foyer and the kitchen. What I want is something that will give me good quality for watching TV/DVD's and listening to music. What I am leaning towards is SVS's SBS-01 5.1 system. It's in the price range I want, $1000.00 and from what I have seen it's a great value. But before I pull the trigger, what I want to know is if you think this is a good purchase, why or why not? If no, what would you suggest in the same price range and why? All help is appreciated. | ||||
| | #2 | ||||
| Re: Newbie need advice/suggestion for 1st HT Welcome Orchitis. glad you are here. As you can see in my signature, I own the SVS SBS-01 system and couldn't be happier. I have owned many speakers from many companies over the years and can say that the SVS's are so neutral that it is very hard to listen to the speakers when watching a movie, because I get so involved with the movie! I have never had a speaker system that hid so well into the background instead of making itself known. I think you will be quite happy with the SVS's. In my opinion, they are the best value in speakers. Have fun, Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #3 | ||||
| Re: Newbie need advice/suggestion for 1st HT I will also attest to this setup... excellent sound and great value. You should be very happy. ![]() | ||||
| | #4 | ||||
| Re: Newbie need advice/suggestion for 1st HT Even though I have moved up from this level, I started out with Hsu. The bookshelf speakers are new since I got my set up and are supposed to be an improvement. This set is $200 over your budget but well worth taking a look at. http://www.hsuresearch.com/products/enthusiast1.html I had a system below these and was very happy with it, as a matter of fact I am still using the Ventriloquist center and rears until I can upgrade them. They offer a 30 day money back guarantee so if you get them and aren't happy all it would cost you is some shipping. | ||||
| | #5 | ||||
| Re: Newbie need advice/suggestion for 1st HT Being in the relatively new HT enthusiast group myself, I went with an Athena Audition series setup which I still use and love. The unfortunate part being that the line has since been discontinued, but having said that, if you want to look used or clearance, that would be the way to go, to get a much fuller response than most HTIB solutions you could come across in that price range. IMO. | ||||
