Home Audio Speakers
Need some advice for Bose alternatives. Please Help
Discuss Need some advice for Bose alternatives. Please Help in the Manufactured Speakers and Subwoofers forum; Need some advice for Bose alternatives. Please Help Hello All, My name is Steve and I am a new guy here from out in New Mexico. I am ...
Views: 970 - Replies: 10
Old 06-06-08, 07:05 PM   #1
svaillan
Inactive
Alias:
User: #
Posts: n/a
Hello All,
My name is Steve and I am a new guy here from out in New Mexico. I am in great need of some advice from all you speaker guru’s. I just moved into a new house and I am looking for speakers for both music and movie watching.
Now my living room is part of an open floor plan with my kitchen. I realize that this layout isn’t the best for acoustics but I couldn’t afford a dedicated theater room just yet. My receiver is an Onkyo 705.
So this brings me to my question. I am looking for speakers that are close to the size of Bose Accoustimas and price as well. They need to be external, not in wall and have a bracket for wall or ceiling mounting. Does such an animal exist?
From what I have read there are plenty of speakers out there that are way better sounding then Bose. I just don’t have any idea of where to begin. I would appreciate everyone’s help and opinion on this search.
Thank You Steve
Old 06-06-08, 08:55 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Need some advice for Boze alternatives. Please Help
Hi Steve, Welcome to the Shack.
Almost all cube type speaker systems sound poor and you will not get much quality sound out of them.
Bang for buck SVS has some really nice speaker packages that would mate up nicely with your Onkyo.
Have a look at these here.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 06-07-08, 03:15 AM   #3
Alias: Matt
Loc: Arizona
User: #3213
Since: Oct 2006
  Matt34 is offline
You may also want to look at AV123's new ELT 525 bookshelf, Acsend Acoustics CBM-170 SE and if you truly need to stay small, Orb Audio. Happy hunting
http://av123.com/index.php?option=co...d=51&Itemid=37
http://www.ascendacoustics.com/pages...70/cbm170.html
http://www.orbaudio.com/
Old 06-07-08, 07:44 AM   #4
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Even if you can just bump up in size a *little* bit. I wish AudioEngine made a passive version of their A2 speakers tunes for about 85-100HZ instead of 65. The only thing I've heard about that size is the Silverline Minuet which is a little bigger ( an inch or two in each dimension) and much more expensive ($600 a pair), but they are very good speakers.
Orb audio is probably your best bet if you absolutely have to stay small.
Old 06-07-08, 11:59 AM   #5
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
The Anthony Gallo Acoustic A'Diva Ti satellite speakers and the TR-2 subwoofer for $2000 sound pretty good for a low footprint set up.
http://www.hometheaterhifi.com/volum...rs-3-2006.html
Old 06-08-08, 12:07 AM   #6
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Welcome to the forum
I started using Infinity TSS750 ... but upgraded to JBL Stadium a couple of months ago
I liked the TSS, but because of the room layout I had them high (near the ceiling) ... and another thing was the crossover (120Hz)
If you can get bigger speakers ... you'll have more options ... and you wont need to upgrade to soon (like me)
Old 06-08-08, 02:27 AM   #7
Alias: Steve
SteveB's Avatar
Loc: Atlanta, GA
User: #3208
Since: Oct 2006
  SteveB is offline
I'm not sure which Bose system you're looking to get. There are some that are 2.1 others 5.1. If you're looking for 5.1 check out Hsu.
http://www.hsuresearch.com/packages.html
That shows all their package deals. The performance package speakers are small like the little Bose and have good sound. I started out with this and still use two speakers as my surrounds. If you get them and aren't happy, you have 30 days to return them.
Old 06-08-08, 12:17 PM   #8
Alias: Matt
mdrake's Avatar
Loc: Central California
User: #16260
Since: Jan 2008
  mdrake is offline
Another option is ORB Audio
http://www.orbaudio.com/?gclid=COH0x...FRIuagodbGm1VA
Old 06-08-08, 04:23 PM   #9
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
mdrake wrote: View Post
Ooh, I hate to do it, but somehow I can't resist...Matt34 beat you to the punch in the 3rd post.
Sorry, you owe me one public ridiculing
Old 06-09-08, 12:27 AM   #10
Alias: Matt
mdrake's Avatar
User: #16260
Since: Jan 2008
  mdrake is offline
I thought I looked it over good. Opps never mind my post.
Old 06-11-08, 03:12 PM   #11
Alias: jakewash
Loc: Calgary
User: #13879
Since: Nov 2007
  jakewash is offline
Re: Need some advice for Bose alternatives. Please Help
I know a number of people really like Kef audio for one more company to add to the audition list.
