Home Audio Speakers
Center speaker connectivity
Discuss Center speaker connectivity in the Manufactured Speakers and Subwoofers forum; Center speaker connectivity Cannot connect center speaker to Kenwood KA-995 integrated amp as the rca center pre out jack will not drive the ...
Views: 1458 - Replies: 5
Old 06-11-08, 11:18 AM   #1
whalstead
Inactive
Alias:
User: #
Posts: n/a
Cannot connect center speaker to Kenwood KA-995 integrated amp as the rca center pre out jack will not drive the speaker. Normally this would connect to Kenwood KM-895 preamp which I did not purchase at the time. Any suggestions for an inexpensive preamp(I assume this is what I need to process/provide enough power to speaker). The center speaker is part of the 5.1 Yamaha NS-SP6500 series and is two 3" woofers with a 3/4" tweeter. I was researching the older Yamaha DSP-100 for this purpose. Also, any problems connecting a rca out(preamp) to a twin lead speaker in(Yamaha center speaker). Any suggestions appreciated!
Old 06-11-08, 11:34 AM   #2
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
Re: Center speaker connectivity
You need an amp, not a preamp. You need to amplify the line-level output (~1volt) to speaker levels (watts) for this. Almost any amp will do for this speaker.
OTOH, before spending $$ on gadgets, consider a modern AVR, even a cheap one would be a great advance over this.
Kal
Old 06-11-08, 11:46 AM   #3
whalstead
Inactive
Alias:
User: #
Posts: n/a
The Kenwood KA-995 is the amp why another/different amp? It has four speaker outs with a sub and a center pre out(both of which connect to the KM 895). I am presently using all speaker outs without any issues as a 5.1 system even the subwoofer connects. Not understanding why I can't drive the center. Working on a budget. I am satisfied with this low end amp and do not want to purchase another if possible.
Signed confused!
Old 06-11-08, 12:25 PM   #4
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
whalstead wrote: View Post
... Normally this would connect to Kenwood KM-895 preamp which I did not purchase at the time. Any suggestions for an inexpensive preamp(I assume this is what I need to process/provide enough power to speaker)...
According to manual you need the KM-895
If I were you I get another A/V receiver instead of the amp for this reasons:
1. Price: a cheap amp will cost $150-200 ( http://www.bestbuy.com/site/olspage....=1109233144936 ) ... just add a couple of hundred and you can get a new receiver.
2. You Kenwood output just 20Watts for the surround ... most new receivers will give you 100 watts
3. Are you sure it will work with just a new amp??? ... manual shows that you have to connect the audio from 995 to 895 then connect all speakers in 895 (I got manuals here http://www.retrevo.com/s/Home+Theater+Systems)
Just my opinion
Old 06-11-08, 12:31 PM   #5
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
... I am presently using all speaker outs without any issues as a 5.1 system even the subwoofer connects. Not understanding why I can't drive the center. Working on a budget. I am satisfied with this low end amp and do not want to purchase another if possible.
You mean 4.1, Right??? (you're not using the center)
I think the sub works because it has his own amp ... but the center speaker doesn't.
We all are in a Budget ... start here to find a nice/cheap receiver http://www.hometheatershack.com/elec...Price&s=pr&p=1
Old 06-11-08, 02:26 PM   #6
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
It has amps for the 4 speakers you mention but, notice, pre outs for center and sub. That means that they come from the preamp inside the KA-995. The KA-995 has only 4 power amps inside. It must rely on external devices for the other channels.
How are you doing this? What and how is everything connected?
Again, because you need an AMP on that channel!
Kal
