Home Audio Speakers
Looking for advice on home theater front speakers
Discuss Looking for advice on home theater front speakers in the Manufactured Speakers and Subwoofers forum; Looking for advice on home theater front speakers I have a home theater set up with a denon 3802 reciever and i'm looking to buy new front towers ...
Views: 683 - Replies: 14
Old 06-12-08, 06:00 PM   #1
Rkmcdon
Inactive
Alias:
User: #
Posts: n/a
I have a home theater set up with a denon 3802 reciever and i'm looking to buy new front towers and center channel. My surround speakers are in wall Klipsch reference series, but i'm willing to have my front speakers not timbre matched to my surrounds if it allows me to get better fronts. I also have a 10" powered sub to pick up the low end. The system is almost exclusively for movies.
The 3 speakers HAVE TO BE less than $1500 total and preferably less than $1400.
I'm far from a speaker expert so i did some searching and discovered a few sets of speakers that seem to fit the bill. Unfortunately, my local store options for auditioning speakers is limited to Best Buy or one "boutique" store with a very limited selection. The current candidates are:
Wharfedale Diamond Series (wildwestelectronics is the only place i could find to purchase these)
9.6 floor speaker
9.cm center channel
Total price $1080
Aperion Intimus 5 Series
5T tower
5C center channel
Total price $1340
Klipsch Reference Series (nearest audition site would be Best Buy, but the nearest Magnolia store is over an hour away).
RF-82
RC-62 center channel
I also discovered a local store is supposed to handle paradigm. I'll check to see what they have in my price range. I'm hoping the monitor 9's will be, but can't find much in pricing online. I'll go ahead and add them to the mix and update once i've heard and priced them.
Paradigm Monitor 9
CC-290 Center channel
I'm mostly interested in getting the best sounding speakers. If you have any knowledge of or opinion on either sets, or if you have another set in this price range you think I should consider, your input would be greatly appreciated.
Thanks
Last edited by Rkmcdon; 06-13-08 at 01:01 PM.. Reason: To add additional speaker selections
Old 06-13-08, 06:21 AM   #2
Alias: Matt
hddummy's Avatar
Loc: ATL
User: #7380
Since: Mar 2007
  hddummy is offline
Re: Looking for advice on home theater front speakers
I've heard several really good reviews about the Aperion speakers and how detailed and vocal they are. You certainly can audition them since the company encourages you take advantage of their free 30 day in home trial with free shipping to you and back if required.
I would like to know if you have any size limitations and what speakers you are currently using. It is hard to suggest a "better" speaker without a baseline.
Old 06-13-08, 08:56 AM   #3
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
I haven't heard the new 5 series, but I have heard the old 4, 5, and 6. The 5s were good, but if you can swing a little extra money for the 6 series, definitely do it.
Old 06-13-08, 12:50 PM   #4
Rkmcdon
Inactive
Alias:
User: #
Posts: n/a
Thanks for the replies
I am currently using a pair of OLD DCM Timewindow 3 towers(each tower has an 8" woofer,6.5" midrange, and 3/4" soft plastic dome tweeter) with a timbre matched center (2 4" drivers and a 3/4" dome tweeter). The center is small and a real weak point in my system. I also have a 10" Energy subwoofer and as i previously mentioned, Klipsch reference in wall surround speakers. The only size limitations are on the center channel, which cannot be over 9"x26"x12".
The setup is my living room and the dimensions are roughly 20' x 16' with a 12' ceiling.
I looked at the 6 series, but it would be an additional $650. I may consider delaying my purchase until i can upgrade to the sixes.
I did discover last night that we have a dealer not far from here that is supposed to carry paradigm. Couldn't find anything on prices though so i don't know if they have anything in my price range. I'm going to check them out this weekend.
Finally, I didn't include these in my initial post, but i suppose I should throw Klipsch in to the mix. I can get a pair of RF-82's and a RC-62 center channel for $1450. Not sure how they compare to the Aperion's or Wharfedales.
Old 06-13-08, 02:18 PM   #5
Alias: Matt
hddummy's Avatar
Loc: ATL
User: #7380
Since: Mar 2007
  hddummy is offline
I think I would order the Aperions and pick up the Klipsch set from BB. Set them up and audition them in YOUR room then return which ever set you don't want. I personally think you pay a bit much for Paradigm...sort of a prestige brand.
Old 06-13-08, 04:21 PM   #6
Rkmcdon
Inactive
Alias:
User: #
Posts: n/a
Turns out the local store I found on paradigms website sells paradigm speakers but doesn't actually carry them in store.
I haven't written Paradigm off entirely, but i appreciate your comment about paying for the brand.
Anyone have any other comments about any of these speakers?
Also, if anyone knows of any other speakers in this price point they think would be worth considering, feel free to chime in.
Old 06-13-08, 04:34 PM   #7
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
If you can go to Magnolia store maybe you can audition other brands they carry ... Definitive Technologies, Martin Logans, etc. ... but I'm not sure about your budget
If you're lucky maybe they will have an open box sale ... yesterday I saw a couple of Definitive for $599 ea originally $1200 ... and Marting Logan $599 from $999
Old 06-13-08, 08:54 PM   #8
Rkmcdon
Inactive
Alias:
User: #
Posts: n/a
salvasol wrote: View Post
Chuckle, maybe i'll see if i can convince my wife to head up to Fayetteville this weekend. Though I doubt i'll be lucky enough to get any 1/2 off deals, but you never know
Old 06-14-08, 05:05 AM   #9
Alias: jakewash
Loc: Calgary
User: #13879
Since: Nov 2007
  jakewash is offline
I'll throw Axiom Audio out there. You should be able to get M60s and the VP150 or VP100 as a center in your price range. They have an audition list on their forum, check it out, you might be able to listen with out purchasing at all.
Old 06-14-08, 10:59 AM   #10
Alias: Matt
Loc: Arizona
User: #3213
Since: Oct 2006
  Matt34 is offline
PSB T65
http://www.psbspeakers.com/products/...mage-T65-Tower
PSB C60
http://http://www.psbspeakers.com/pr...age-C60-Center
Old 06-16-08, 07:38 PM   #11
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
SVS MBS-01 and the SVS MCS-01.. ok, ok, it's $999+$599=$1,598, but from everything I've heard, SOOOO worth it. Also, maybe you can find someone to split an order for the MBS-01's. That'd be better anyway.
JCD
Old 06-17-08, 12:01 PM   #12
Rkmcdon
Inactive
Alias:
User: #
Posts: n/a
I auditioned the Klipsch RF-82's with the RC-62 center this weekend. They were nice, definitely better than my current speakers, but seemed to be missing something. I've not auditioned many speakers, so i couldn't quite put my finger on the problem.
The SVS and PBS's look nice, but the svs are going with bookshelve speakers and still just over my price range, and the PBS's unfortunately are a good $250+ over my price range
Have had no luck finding Paradigms to audition or even a price.
I did have someone suggest Infinity Beta 50's with the C360 center.
Old 06-17-08, 01:04 PM   #13
Alias: Konky
conchyjoe7's Avatar
Loc: Canton, GA USA
User: #11137
Since: Aug 2007
  conchyjoe7 is offline
I personally think it will be tough to find better than the Aperions for the money, but as always you MUST listen for yourself.
Good luck, and cheers...
Konky.
I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns.
Old 06-18-08, 05:40 PM   #14
Rkmcdon
Inactive
Alias:
User: #
Posts: n/a
Thanks Conchy. Have you heard the 5 series in the aperions?
I'd also love to hear from anyone who has listened to the wharfedales.
Old 06-24-08, 10:43 PM   #15
Alias: Matt
Loc: Arizona
User: #3213
Since: Oct 2006
  Matt34 is offline
Rkmcdon wrote: View Post
I would really make an effort to listen to the Infinities. The cheaper Primus 360 measured very well during a Stereophile review.
