Home Audio Speakers
Why do I hear dialogue from surround speakers?
Discuss Why do I hear dialogue from surround speakers? in the Manufactured Speakers and Subwoofers forum; Why do I hear dialogue from surround speakers? During movie dialogue I am hearing an echo. I hear dialogue from the center and surrounds. The volume from the ...
Views: 438 - Replies: 1
Old 07-05-08, 11:45 PM   #1
Alias: Dwight
Loc: Barrie Ontario Canada
User: #14446
Since: Dec 2007
  Dwight Angus is offline
During movie dialogue I am hearing an echo. I hear dialogue from the center and surrounds. The volume from the surrounds is much lower and slightly delayed. Hence the echo effect. Also the dialogue is not constant from the surround. Can someone tell me why this is happening?
Old 07-06-08, 04:42 AM   #2
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Re: Why do I hear dialogue from surround speakers?
Well, you should be hearing it from your center, but not your surrounds (unless it's a scene set in a cave). My best guess would be that you have the wrong surround decoding option selected, one of the funky "music" or "movie" modes that converts 2 channel into 5 channel using simple reverb algorithms.
Double check to make sure that you are on the most basic Dolby or DTS decoding.
