Greetings - I have decided it's time to have fun in the world of testing out products, and this time, it's going to be in floorstanding speakers.
As of now, we have a pair of Klipsch LaScalas and a pair of Martin Logan Electromotion ESL Hybrid Electrostats, with a pair of Axiom M100's and a pair of M50's on order.
The Klipsch retail for $7000 per pair, and are quite the revealing loudspeaker. Those who have not heard a pair of Klipschorns or LaScalas are missing out on something special.
Sam Tellig, famed audio critic, tested the LaScalas here: Sam likes him some LaScalas
The Martin Logans can be found here: Martin Logan Electromotion ESL
The Axioms will be delivered at a later date, and we will start discussion at that point.
The first speaker "up" will be my spending several weeks listening to the Martin Logans in a simple two channel set up.
The front end is a Denon Universal player with a Marantz 7008 receiver. All processing is turned off. No subwoofer is being used. It's just a straight, two channel set up.
The reason I finally selected the Marantz is it delivers 148 WPC into 8 ohms and 216 WPC into 4 ohms, as measured by Sound and Vision here: Bench Test on Marantz 7008.
In addition, the Marantz has preouts on all channels, and for later tests has full Audyssey XT-32 processing with sub eq which can independently eq two subwoofers.
It also allows one to bypass Audyssey on the mains, should one wish to have a sub in one's system, properly eq'ed, but without processing in the Left/Right speakers.
All speakers being tested are being purchased by me, no manufacturers "giving" free product for evaluation. I have contacted several manufacturers, and am waiting on responses for other speakers to be added over the next few months.
I will do the best I can to convey to relative "sound qualities" of each loudspeaker. More later, as some serious listening will start this week.
Speakers by Brand and Model, including post numbers where one can find them:
1. Martin Logan Electromotion ESL Hybrid's can be found in posts #4, 5 and 6
2. Axiom M50 can be found in posts #39, 40 and 41
3. Axiom M100 can be found in posts #43, 44 and 45
4. Legacy Audio Signature SE can be found in posts 46, 47 and 48
These notes will take place over the next 3 to 4 months, and the reason for the dedicated three pages per speaker is to allow an easy place for the summary notes on each speaker. There will also be the more frequent updates throughout the thread. Hopefully, this will work for both the occasional reader and the more avid forum members.
