Home Audio Speakers
Speaker Advice
Discuss Speaker Advice in the Manufactured Speakers and Subwoofers forum; Speaker Advice I have a onkyo 606 on the way I have a panny 58px60U TV I have a play station 3 ...
Views: 463 - Replies: 5
Old 08-09-08, 09:44 PM   #1
New Member
Alias: fife
Loc: Michigan
User: #24141
Since: Aug 2008
  1fife is offline
Speaker Advice
Looking for some speakers for the family room(its fairly big 21x24)
I dont want to spend more than a $1300(1000 would be better).
Can i use the speakers i have(listed below), or should i start all over?
What should i be looking at ?
Thanks in advance
I have some older cerwin vega speakers(woofer builtin) and a center channel. The speaker are model RL-18P. Spec lsited below
Cerwin Vega RL 18P
1 reviews ( views/week) 1 of 5
MSRP: $ 1000.00
Pair
RL-18P Description: 8" 3-way power tower with built-in subwoofer amplifier
Frequency Response (+/-2 dB): 35 - 20 kHz
Recommend Power: 20 - 150 watts
Amplifier Output: 100 Watts RMS (@0.05% THD)
Amplifier Features:
Variable woofer gain; line lev
Pair
Amplifier Features:
Variable woofer gain; line level input; speaker level input; 115/230 AC
Sensitivity: 92 dB
Impedance: 6 ohms nominal
Protection: AC fuse; self-resetting PTC
Video Shielding: Yes
Dimensions (H x W x D): 43 1/4" x 10" x 14 1/2"
Weight: 56.6 lb./25.6 kg
Finish: Black woodgrain vinyl
Description: Pair
Amplifier Features:
Old 08-10-08, 08:53 PM   #2
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is online now
Re: Speaker Advice
Personally, I'm not a big fan of Cerwin Vega's,... though I did have a buddy who had some awesome Cerwin Vega party speakers back in the early 80's
Of course you can use what you have,... that is, if you like the sound of 'em. If not??? I'm not familiar with anything that would fit within your budget and fill that size of a room. I'm sure someone will have a good idea or two.
Mark
Old 08-10-08, 10:19 PM   #3
Owner
Loc: L.A. (Lower Bama)
Re: Speaker Advice
Our great room is about this size with huge openings. We had the SVS SBS-01 system in here a while back and it sounded very good. It was not mind blowing, but it was very good and I could be pleased with it. That system is $1000 system with sub.
At present we are running Ascend Acoustics Sierra 1's across the front with CBM-170's for rears. You wouldn't be able to get the Sierra 1's by you could get a nice Ascend setup and an SVS sub for around $1300.
Your options are truly limited.
Old 08-11-08, 09:56 AM   #4
Alias: TLC
Loc: Dartmouth NS
User: #22937
Since: Jul 2008
  Toolatecrew is offline
Re: Speaker Advice
If I were in your sitution and my room layout would accomadate it I'd do the following.
Move the RL 18P to the BACK. Use them for surrounds.
Start combing used listings for 2 front towers and a center. Look for somwething with good sensativitey (90db plus) that your new reciver can easily dirve to help fill that big room with sound. I have no idea what kind of sound you like so I won't suggest a brand just as an example you might find something = to Paradigm Monitor 9 and CC370 out there used in your budget.
Does that 1300 include a sub?
Trying to buy a complete 5.1 system for less than $1300 new that will not get lost in the big romm is pretty unlikley.
Old 09-13-09, 09:33 AM   #5
New Member
Alias: Rob
Loc: Prince George, Virginia
User: #38570
Since: Jun 2009
  woodsart is offline
Re: Speaker Advice
1fife wrote: View Post
Thanks in advance
Cerwin Vega RL 18P
MSRP: $ 1000.00
Pair
Amplifier Features:
Pair
Amplifier Features:
Sensitivity: 92 dB
Description: Pair
Amplifier Features:
Thought I would chime in here, hopefully you have found your set-up by now, however, if not I have a suggestion. Have you thought of the Infinity Primus Line of speakers. IMHO, and for the money paid, they are truly the best kept secret on the market. Check them out Fronts Primus P362 Center P350 and the P142/P152 or P162 for surrounds. I have read extensively they are in your price range. The majority of us buffs are extremely budget minded and looking for the best prices. This, of course, should only be considered if you haven't made your theater purchase. I can supply some info that might help. Otherwise, disregard this post.
I would be interested in what type of set-up you ended up with anyway.
Thanks.
Old 09-13-09, 11:22 AM   #6
Shack Moderator
Alias: Jon
Loc: Irvine, CA
User: #9090
Since: May 2007
  Jon Liu is offline
Re: Speaker Advice
There are several companies that I would suggest, SVS (suggestion already made by Sonny), Axiomaudio.com, and AV123 (especially the X-Series).
I've heard all their speakers and they are bargains for the price. You'll likely be able to find a set of speakers in there for within your budget.
Hope this helps!
Outside of a dog, a book is man's best friend. Inside of a dog it's too dark to read." - Groucho Marx
advice, system
