Home Audio Speakers
I need a price check
Discuss I need a price check in the Manufactured Speakers and Subwoofers forum; I need a price check I was cleaning out a closet and ran across an old HT setup I had. I'm just wondering what its ...
Views: 437 - Replies: 3
Old 08-11-08, 02:31 PM   #1
simmons4102
Inactive
Alias:
User: #
Posts: n/a
I was cleaning out a closet and ran across an old HT setup I had. I'm just wondering what its worth now. I hooked up and its all GTG. I haven't been able to find any data on this stuff.
Boston Acoustics SubSat6 3-piece set (RF, LF, Dual Channel Sub)
Boston Acoustics HD5 Bookshelf speakers
Advent A1102 Center channel
I have stands for the SubSat6 L & R channel speakers and universal wall mounts for the HD5s?
Thanks in advance.
Old 08-11-08, 03:12 PM   #2
Owner
Loc: L.A. (Lower Bama)
  Sonnie is offline
Re: I need a price check
Moved to Home Audio Speakers.
Welcome to the Shack!
I would say maybe a couple hundred bucks at most... if even that.
Old 08-12-08, 04:20 PM   #3
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
I'm not sure either.. but what I'd do is go to eBay and check out the old auctions for the speakers you've got.
Another source would be to take a look on Audiogon.com or Videogon.com and see if you can find the same speakers.
JCD
Old 08-13-08, 02:35 PM   #4
Alias: Konky
conchyjoe7's Avatar
Loc: Canton, GA USA
User: #11137
Since: Aug 2007
  conchyjoe7 is offline
Welcome to the shack. With all due respect, we are not here to run your "price checks". This is not K-Mart. I believe you've received enough info to go and do them yourself...sheesh!
That said; it should certainly be easy enough for YOU to find the worth of what you have.
I get up...I get the paper...I read the obituaries...if I don't see my name; I go ahead and have breakfast! George Burns.
check, price
