budget prob max $500-600 ea speaker , prob plan on upgrading within 6 months dont got the money right now.
Maybe $300-600 range per tower. Id prob need 3 though so 1 is a center channel.
I am open to more pricey suggestions though , if sound quality is amazing.
Have you considered the used market in your area. The used market can give you huge performance vs dollar value gains. While it doesn't help the general economy - it helps the seller and most of all - it helps you too :nerd::T
Try and find a used pair of Image T6 ... NOT to be confused with the previous generation Image 6T ... In terms of bass, they will readily blow most of whats mentioned in this thread out of the water. Stereophile has rated them very high in sound quality, imaging, and bass response.
I believe the T6 MSRP was around $1099.00 but if you can find a pair for around $500, your getting one excellent speaker.
Related Threads
742.3K posts
170.9K members
Since 2006
