Home Audio Speakers
Where to purchase micro speakers for RV?
Discuss Where to purchase micro speakers for RV? in the Manufactured Speakers and Subwoofers forum; Where to purchase micro speakers for RV? I have a HTS in my RV but the speakers are too large and sometime cause headaches. Sony has a ...
Views: 1321 - Replies: 6
Old 09-05-08, 08:43 AM   #1
georgetownsteve
Inactive
Alias:
User: #
Posts: n/a
I have a HTS in my RV but the speakers are too large and sometime cause headaches. Sony has a Bravira DAV-IS10 system that has the speaker size I would like (about the size of a golf ball) I would buy the new system but the amplifier is to big for the available space. Where can I get small speakers?
Thanks, Steve
Old 09-05-08, 08:46 AM   #2
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
  BoomieMCT is offline
Re: Where to purchase micro speakers?
Are you looking to make them or buy something off the shelf? It sounds like the latter.
Old 09-05-08, 08:48 AM   #3
georgetownsteve
Inactive
Alias:
User: #
Posts: n/a
Buy them off the shelf.
Old 09-05-08, 08:55 AM   #4
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
1) This should really be in the Manufactured Speakers and Subwoofers section then, not DIY. You'll likely get more answers there. Some moderator should move it over. Oh wait, I might be able to do that.
2) Assuming you are looking just for micro speakers there are many good systems out there as this has been popular at least since Bose marketed their micro-cubes forever ago. I'm not super excited about Bose but I've heard good things about Orbaudio, Hsu, SVSound, Axiom, AV123, HTD, . . . Most of these excellent brands have link buttons above - go to those first. Perhaps with more information about the size and budget limitations you have better answers can be given.
Old 09-05-08, 08:57 AM   #5
Alias: Boom
BoomieMCT's Avatar
Loc: Fairfax, Va
User: #4757
Since: Dec 2006
Re: Where to purchase micro speakers for RV?
Moved from DIY speakers to Home Audio Speakers.
Old 09-05-08, 11:58 AM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
I have heard good things about Orb audio as they are small but still sound good. The golf ball sized speakers you are referring to will not be very good at all and you wont get any decent volume out of something that small.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-06-08, 09:13 AM   #7
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Those Sony's sound horrible. Stay away. Good suggestions, but if you don't need 5.1, consider self-powered like the Audio Engine A2 (No amp, just connect your DVD player. Maybe a pic of your setup (available space) would help. Do you have room for a subwoofer?
