| Home Audio Speakers Yamaha opinionsDiscuss Yamaha opinions in the Manufactured Speakers and Subwoofers forum; Yamaha opinions I was thinking of adding YAMAHA NS777 floor standing speakers and the YAMAHA SW315 to the theater i am planing. ... |
Views: 406 - Replies: 3
| | #2 | ||||
| Re: Yamaha opinions They have good reviews over at audioreviews. If you like the way they sound and the price is right, go for it. | ||||
| | #3 | ||||
| Re: Yamaha opinions Yamaha makes a decent product and is not over priced for what you get. However you should give a listen to other brands in the same price range. You can also look at used speakers this way you get a better brand for less. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | ||||
| Re: Yamaha opinions Hello, Best speaker yamaha ever made was NS-1000 and NS-1000M. They have berylium mid and tweeter and 12 inches woofer. I am lucky enough to have 6 NS-1000 in my HT system with Rotel Components and Amps. You can find ns-1000 on ebay for arround 1500. It is a good alternative to new speaker. Jean-Pierre Imbeau ROTEL RSP-1098|RCD-1072|RDV-1060|RT-1080|RLC-1040|RB-1080x2|RMB-1075|RSP-976 PIONEER ELITE PRO-940HD|BDP-HD1|inno|YAMAHA NS-1000|NS-1000M|CA-1010|CT-1000|TC-1000| YP-1000|PEERLESS XXLS-12x4|HP MediaCenter (Vista Madia Center) + HP MediaSmart Server (Windows Home Server) with 4TB 2.0 TB|BEHRINGER DSP1124P|ECM8000|TOSHIBA HD-A2 My Peerless subs building thread | ||||
