Home Audio Speakers
in ceiling speakers?
Discuss in ceiling speakers? in the Manufactured Speakers and Subwoofers forum; in ceiling speakers? I have been trying to decide if I want to use in ceiling speakers or not. With the room i ...
Views: 805 - Replies: 5
Old 09-06-08, 08:30 AM   #1
bawalte1981
Inactive
Alias:
User: #
Posts: n/a
I have been trying to decide if I want to use in ceiling speakers or not. With the room i will be using it would be great for space saving. Will Boston Acoustics DSi255 be any good for a theater? Any opinions or advice?
Old 09-06-08, 12:46 PM   #2
Alias: thxgoon
thxgoon's Avatar
User: #6924
  thxgoon is offline
Re: in ceiling speakers?
To be honest in ceiling speakers are not the best choice for theater being that they are at such an extreme angle relative to the listening position. Can you mount them in the walls on the side of the screen? If in ceiling is your only choice, those boston's should work out nicely
Old 09-06-08, 03:02 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
In ceiling/wall speakers tend to be very directional so if your not sitting directly by it you wont hear much from them unless your ceiling is at least 12' high. They also dont usually have the db output or power handling capabilities that good bookshelves or floor standers have.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 09-07-08, 02:43 AM   #4
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
+1 vote for inwalls or onwalls.
Old 09-09-08, 04:42 PM   #5
Alias: Jeff
Loc: Indialantic, FL
User: #25509
Since: Sep 2008
  jsink77 is offline
Any suggestions on brands - I got a pair of jamo 10.5k4s for cheap, but not overly pleased with the low end response?
Old 09-12-08, 11:02 AM   #6
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is online now
I would also suggest in-wall over in-ceiling.
As for brands,... depends on your budget. I would also say this is not the place to try and save cash. You will have to spend quite a bit more to get good high quality in-wall/in-ceiling as opposed to in room speakers. There are a lot of in-wall/in-ceiling speakers marketed by many different companies but there are very few really good ones.
RBH Sound You have probably not heard of them, been around over 30 years. They have a lot of experience with in-wall and in-ceiling speakers. They were also one of the first to design in-wall/in-ceiling speakers with an enclosure. RBH speakers are marketed under several different brands including: Status Acoustics high end line, Destination Audio, and EMPTek internet direct sales.
Triad an excellent source for high quality speakers.
James Loudspeakers
Snell Acoustics
Mark
ceiling, speakers?
