| Home Audio Speakers Question on speaker rangeDiscuss Question on speaker range in the Manufactured Speakers and Subwoofers forum; Question on speaker range I was wondering, if I had speakers for my mains that topped out at 16khz what or how much would ... |
Views: 531 - Replies: 11
| Question on speaker range I was wondering, if I had speakers for my mains that topped out at 16khz what or how much would I miss from mains that would go to 20khz. Would it be profound or barley missed. Also I am 51 and I don't know what if any difference that would make in hearing different frequency's. THANKS....... | ||||
| | #2 | ||||
| Re: Question on speaker range For digital recordings you will be missing the higher frequencies even though we generally only hear up to about 16k there is still information that is heard higher than that even as high as 22k. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #3 | ||||
| Re: Question on speaker range You won't miss much. There's not much content in most recordings above 16khz, and supposedly by the time we are 35 hearing sensitivity at those frequenices is all but gone anyways. What you might consider is that a speaker designed to go up to 20khz might be better designed for the rest of the spectrum as well. What speakers are you looking at? | ||||
| | #4 | ||||
| Re: Question on speaker range I don't think you would notice a major differance. There would be some resultant frequencies that might make for a more natural sound if you had speakers that went higher in the frequency range. Dennis Posted via Mobile Device | ||||
| | #5 | |||||
| Re: Question on speaker range Quote:
| | #6 | ||||
| Re: Question on speaker range they would be very effecient, but, they are designed for large venues. You might not like them in a home setting. If you have heard them any like their sound, them go for it. Dennis Posted via Mobile Device | ||||
| | #7 | ||||
| Re: Question on speaker range I am really torn on this, I mentioned it to the wife and she just said, it's your room do what you like. I could bi-amp the JBL'S and a pair of nice Polk bookshelf speakers I have with my Pioneer but I fear I am getting out of control, even though the money is reasonable. Decisions, Decisions..... ![]() | ||||
| | #8 | |||||
Unless the numbers of two speakers come from an independent source who knows how to test consistently, I'm not sure how useful upper frequency response is as a predictor of performance. People differ. Even at 57 I can hear up to 15k, although it's by no means flat! Doug | |||||
| | #10 | ||||
| Re: Question on speaker range Well the truth is the speakers I have sound fine. They are Cambridge soundworks Tower II's but I was thinking that the JBL's would really bring the movies to life especially in the mid bass region. | ||||
| | #11 | |||||
You can get a pair of those at ebay for around $500 or less ... I own the Venue Stadium (discontinued) and I'm happy with them (the L's series are suppossedly two steps above the Venue's) ![]() Last edited by salvasol; 09-06-08 at 05:45 PM.. | |||||
| | #12 | ||||
| Re: Question on speaker range Thanks, I'll take a look......... | ||||
