| Re: Driver break in volume/hrs Driver Break in, This is a hot question open to alot of discussion, Driver break in is not a science and I do believe that drivers need time to break in but it depends on the make, size, quality and kind of sound you use to break it in. So to give you a defiant time line is almost impossible. In my opinion a month of normal use is plenty. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR My Webpage |
