| Home Audio Speakers sugestionsDiscuss sugestions in the Manufactured Speakers and Subwoofers forum; sugestions ok i have a yamaha htr-5940 amplifier and right now i have just some mismatched speaker on it nothing special ... |
Views: 328 - Replies: 10
| sugestions ok i have a yamaha htr-5940 amplifier and right now i have just some mismatched speaker on it nothing special ... but ok first i better say im completely new to this stuff so i may sound stupid. The subwoofer input is a aux spot on the back instead of just the normal speaker wire like i was use to so my subs arent exactly being used right but i was just wondering what would be a good cheap set of speakers i could get for this to go along with what i have since i need to get a subwoofer that hooks up like that im not quite sure how to do it. please help me out i mainly use it for audio but ocasionally use it for home theater. Thanx | ||||
| | #2 | |||||
| Re: sugestions First of all ... Welcome ![]() Quote:
![]() What is your budget??? ... ARe you looking for a 5.1 system??? ... How big is your room??? | |||||
| | #3 | ||||
| Re: sugestions well i use it to supply sound to my whole house for parties but my house isnt really that big just a 1 story 3 bedroom so not big at all really but right now i took a set from my friends toshiba soround sound set and the sub and put ir on right speaker then i had a screwed up divinci set and one of the subs from the dbl sub it had hooked to the left and then 2 of the divinci small speakers and 2 of the toshiba small speakers hooked up and the toshiba center one... ya i know its completely ghetto but it sounds really good actually but i have to turn the volume up pretty high for it to sound good so i just think upgrading the speakers would be better im noot looking to spend all that much so just try to go as cheap as possible... i was thinking of using car subwoofers to use as the subs for the theater but dont really know how to wire that up and at what ohms to have the subs at or anything like that so as you see i need some help!! | ||||
| | #5 | ||||||||
| Re: sugestions Don't worry about the link ... I already saw the specifications (before I repplied the first time )Quote:
)Quote:
... but I'm sure they're small speakers, same used in HTIB (Home Theater in a Box).Are you planning to get tower, bookshlef or do you need small speakers??? ... Quote:
![]() Also, You want the 6.1 Right??? ... or can you get some right now and add the rest later??? Quote:
Have you checked ebay, craigtlist, audiogon for good deals on used speakers??? ... if you're short of money, those are good places to find good deals ![]() | ||||||||
| | #6 | ||||
| Re: sugestions Here is a couple of systems so you can start shopping around Fluance speakers , Fluance 5.1 and Yambeka speakers There's al ot of speakers to choose from ... but it will depend on your budget and what you're looking for. ![]() | ||||
| | #7 | ||||
| Re: sugestions ill prob buy piece by piece as i get money ummm i dont really know how much soround sound stuff cost now of days but id like to spend less than 300 even tho i dont think thats possible... i will try to get the models tomorow but the toshiba kit is a soround sound kit that u can buy from best buy and the three speakers im using from divinci are from the pro line and im using 1 of the 2 subs it had and 2 of the lil speakers that come with it. Im looking to use bookshelf speakers and its definately got to have some bass to it and thats why i was thinking of using car subs as subs for the setup. Hope that helps out some | ||||
| | #8 | |||||
| Re: sugestions It is possible ... just remember that you'll get what you paid for ![]() You can start with a pair of nice bookshelf speakers ... then add a good sub, then a center, and finally surrounds (if you can still use the old speakers). Here is a review of the speakers I suggested above ( Yambeka ... they cost $299 and Fluance $199 for a set of five speakers )... I have some Fluance (BP1) that I don't use anymore because of the frequency response ![]() Quote:
| | #9 | ||||
| Re: sugestions ok thanx for the info on the frequency response... is there some websites where u can buy like multiple diferent brands of speakers at the same place... Life for example i buy my car audio from sonic electronics and crutchfield etc | ||||
| | #11 | ||||||
| Re: sugestions Quote:
![]() Quote:
Connect from speaker terminals on the 5940 to speaker terminals on the sub (it will be labeled input or from receiver,etc); then, in the same sub there will be another set of speaker terminals that output the audio to speakers ... from there, you'll make the connections to each speaker ![]() In other words, you have a passive sub, it will get the sound from AVR and it will transfer the sound to speakers ![]() If you can, post the brand and model of the sub to double check the connection ... ![]() | ||||||
| Bookmarks |
| Tags |
| sugestions |
| Thread Tools | |
