Home Audio Speakers
Magnepan MMG with MMG-W (surrounds) crossover questions
Discuss Magnepan MMG with MMG-W (surrounds) crossover questions in the Manufactured Speakers and Subwoofers forum; Magnepan MMG with MMG-W (surrounds) crossover questions Hello all, I am really intrigued by what I have read about the Maggie sound... I have never heard a ...
Views: 926 - Replies: 3
Old 10-02-08, 04:04 AM   #1
New Member
Alias: dkolacz
Loc: Buffalo, NY
User: #26376
Since: Sep 2008
  dkolacz is offline
Hello all,
I am really intrigued by what I have read about the Maggie sound... I have never heard a pair or quartet in action but I think it is just what I am looking for to make surround sound gaming on the 360 really come alive.
I can either go with all MMGWs and an Outlaw LFM-1 Plus subwoofer....or
go with MMGs (better response) as the fronts and MMGWs as the surrounds (with Outlaw sub as well)
My only issue is that my Pioneer Elite VSX-82TXS receiver does not have seperate crossover for fronts and surrounds....(maybe it does, but from what I can tell bouncing around in the menus...no)
The MMGs go to 50Hz and the MMGWs go down to 100Hz...so I would have to set the receiver to crossover at 50Hz....I am not an expert at all, but I think I would be losing information on the rear channels...correct? Any way around this ? Or is it not really a big deal since they are surrounds.
Thanks alot !
Old 10-10-08, 02:08 PM   #2
Alias: chad
User: #16811
Since: Feb 2008
  chadci is offline
Re: Magnepan MMG with MMG-W (surrounds) crossover questions
I'm toying with the idea of getting a pair of W's for my 2 channel rig. If they go down to 100, I would cross over there, maybe even 120 if you can. Hopefully your sub will play that high and they can blend together well.
Maggies sound beautiful, however, they are tricky. VERY power hungry and usually a 4ohm speaker so you have to be very careful about what you use to power them with.
Old 10-23-08, 09:24 PM   #3
Alias: superchad
Loc: ohio
User: #17760
Since: Mar 2008
  superchad is offline
I would be really nervous your reciever wont be up to those poser hungry speakers, I have powered them with as little as 120W of Rotel power but a reciever may or probably wont be enough.
Old 10-23-08, 10:09 PM   #4
Alias: Kal
Loc: NYC + CT
User: #1881
Since: Aug 2006
  Kal Rubinson is offline
dkolacz wrote: View Post
Thanks alot !
I would go with 100Hz all around if you must use the same frequency for all channels. Even if you can, I would not cross the MMGs below 80Hz or the MMGWs below 100 or 120. You want to crossover 20Hz or more above the -3dB point.
Kal
(surrounds), crossover, magnepan, mmg-w, questions
