Home Audio Speakers
Ascend 340SE's to Sierra's
Discuss Ascend 340SE's to Sierra's in the Manufactured Speakers and Subwoofers forum; Ascend 340SE's to Sierra's A question. I have my 340SE mains mounted about 4-5 inches away from the wall on B-Tech BT-77 mounts. My ...
Views: 610 - Replies: 11
Old 10-17-08, 04:39 PM   #1
Gov
Alias: Gov
Loc: NW burbs of Chgo,IL
User: #13627
Since: Nov 2007
  Gov is offline
A question. I have my 340SE mains mounted about 4-5 inches away from the wall on B-Tech BT-77 mounts. My center 340SE is on a shelf above my TV and its about 10 inches from the wall. My system is always run "small" crossed at 80hz with a Mirage S12 subwoofer. My room is about 16ft X 18ft wide, 8ft ceilings, open to a kitchen. The main seating area is about 14 feet away from the front 3 speakers. I use an Emotiva LPA-1 amplifier which is high current. Considering this set up, do you think I would benefit from getting Sierra's to replace the 340's? Will I be able to hit relatively high SPL's with the Sierra's? As far as my listening habits, I am about 60% movies 40% music
Thanks
Old 10-17-08, 04:56 PM   #2
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Ascend 340SE's to Sierra's
First of all ... Welcome
Gov wrote: View Post
Looking at the specifications and your set up ... I think you're fine with the 340's
If you change to Sierra's you will just gain a little in the frequency response from 45Hz you'll go down to 30Hz (and I think don't matter because your crossover is set @ 80Hz) but you will loose in the sensitivity (340's are rated at 92 and Sierra's 87)
What are you trying to improve in your current set up??? ... or is the upgraditis virus that is itching???...
Old 10-17-08, 05:02 PM   #3
Alias: Andrew
avaserfi's Avatar
Loc: College Station, TX
User: #9992
Since: Jul 2007
  avaserfi is offline
The Sierra-1s will have subjectively superior sound quality due to their less resonant cabinet. If you are interested in having a more realistic presentation of music playback for critical listening the Sierra-1s will be a significant upgrade. On the other hand, if your primary objective is movies your current set up is sufficient.
Andrew
Old 10-17-08, 05:18 PM   #4
Gov
Alias: Gov
User: #13627
Since: Nov 2007
  Gov is offline
salvasol wrote: View Post
Thanks! And yes, a bit of upgraditis I am happy with the 340SE's and they are a very easy to drive. At times I think my LPA-1 is overkill for them. I have also considered getting a Denon 2809ci as a pre/pro or the new Emo processor the UMC-1 when it comes out in December. I like the Dynamic volume and EQ implementation. I have not heard it yet, but it gets rave reviews. Also, I am currently using a Pioneer VSX-1014 as a pre/pro that does a nice job, but the MCACC on it I am not crazy about.
Old 10-24-08, 09:21 PM   #5
Gov
Alias: Gov
User: #13627
Since: Nov 2007
  Gov is offline
I wound up getting a Pioneer Elite SC-05 and decided to keep my 340SE's
Thanks
Old 10-24-08, 09:39 PM   #6
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Thanks
Old 10-27-08, 10:23 AM   #7
Alias: Mazer
mazersteven's Avatar
Loc: Melbourne, Florida
User: #8008
Since: Apr 2007
  mazersteven is offline
IMO if music is a priority. Then yes you would benefit from the Sierra's. But if your systems primary use is HT. Then I say your gains would be very small.
Old 10-28-08, 10:29 AM   #8
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
Thanks
When you have a minute, could you provide a review? I've got 340's and I'm thinking about getting the SC-05 to replace a good sounding but very limited (and cheap) Panny XR57.
The Panny has only one HDMI in and out. It's a major PITA. I'm using a switchbox for my PS3 and Dish receiver. It also has an LFE bug that's irritating.
Thanks,
Doug
Old 10-28-08, 03:15 PM   #9
Gov
Alias: Gov
User: #13627
Since: Nov 2007
  Gov is offline
I bought one and it is great! It puts out very little heat and at spirited levels sounds very good with Ascends. The GUI for set up is nice and very user friendly. I have run the advanced MCACC and like all the results I get except, no matter which way you cut it, I prefer the EQ off with my Ascends. The full band phase and standing wave if fine, and it sets the channel levels and distance almost perfect.
The THX Loudness Plus feature is ok, but nothing great. I have a feeling Audyssey's dynamic volume/EQ works better.
The build quality is superior and it is some serious eye candy.
At the moment, I do not use the video portion of this receiver, but I guess it works well and is pretty much bug free from all reports.
Old 11-17-08, 02:26 PM   #10
Alias: Brandon
Loc: WI
User: #27993
Since: Nov 2008
  Nuance is offline
avaserfi wrote: View Post
+1. I've heard them both and that is a real good way to describe the difference. However, if you want descriptive terms, the Sierra's are smoother, reach lower and don't sound as "boxy." The bass is quite impressive for a bookshelf style speaker, IMO.
Old 11-17-08, 03:48 PM   #11
Alias: Doug
Loc: Juliette, GA
User: #15964
Since: Jan 2008
  DougMac is offline
Nuance wrote: View Post
I love my 340's but if I were pressed to find a fault, it would be that under certain circumstances they can sound boxy. By that I mean there are certain low frequencies that seem to resonate. Certain notes on bass guitar or acoustic bass brings this out. I've never noticed boxiness on vocals though, even low bass vocals.
I read a trick on a forum (I can't remember where) that has made the boxiness disappear. I set the bass to -1 or -2 on the receiver, then increase the gain of my sub slightly. I have my crossover set at 80 hz. This seems to push the "handoff" point to a slightly higher frequency, allowing the sub to handle more in the <100 hz range.
There's an added bonus. With more gain for the sub, the house curve is better which brings up the deep bass (<35 hz).
Doug
Old 11-17-08, 04:30 PM   #12
Alias: Brandon
Loc: WI
User: #27993
Since: Nov 2008
  Nuance is offline
DougMac wrote: View Post
Doug
That's awesome - glad you got the "trick" to work!
Also, don't think I didn't like the 340's; they are good speakers for the price. I just liked the Sierra-1's more, which is good because they cost more and should be better.
340se's, ascend, sierra's
