Home Audio Speakers
klipsch rs 3II as center channel.
Discuss klipsch rs 3II as center channel. in the Manufactured Speakers and Subwoofers forum; klipsch rs 3II as center channel. I was wondering if I could use a klipsch rs 3II as a center channel? I have klipsch rf 3II ...
Views: 418 - Replies: 7
Old 11-23-08, 09:48 PM   #1
New Member
Alias: brian
User: #29192
Since: Nov 2008
  fatherofone03 is offline
I was wondering if I could use a klipsch rs 3II as a center channel? I have klipsch rf 3II in the front and klipsch rs 3II in the back. I also have the matching klipsch 12" powered sub. I dont have the money for the matching center channel so I was wandering if I could use one of the extra rs 3II I have as a center channel until I can get the matching center channel?
Old 11-23-08, 10:05 PM   #2
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Re: klipsch rs 3II as center channel.
First off,... Welcome to the Shack.
Definitely, in fact it should work much better having all speakers the same.
Mark
Old 11-23-08, 10:12 PM   #3
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Oooh,..just noticed that you said RS-3 II not RF-3 II,.... well the RS will work but it will not be near as good as having an RF-3 II as the center. But you most likely would not be able to use another RF-3 II as a center. I'd still go ahead and try the RS- 3 II as a center, at least until you can get another RF-3 II or an RC-3 II
Mark
Old 11-23-08, 10:15 PM   #4
New Member
Alias: brian
User: #29192
Since: Nov 2008
I appreciate the help. Just seems like a good temporary fix until I get the matching center.
Old 11-23-08, 10:18 PM   #5
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
And if it sounds terrible, you could always use a phantom center until you get the RC-3 II.
Mark
Old 11-27-08, 11:38 AM   #6
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is online now
The RS 3ii is a dipole right? I wouldn't use that for a center. I mean, it would be an interesting experiment, but I'd wager it's going to sound weird.
3 identical speakers across the front is definitely a good thing, I'd save up for that. Keep looking around Audiogon and ebay. With some patience, you can find some amazing deals.
Old 11-27-08, 09:44 PM   #7
Banned!
Alias: alan monro
alan monro's Avatar
Loc: Melbourne Australia
User: #465
  alan monro is offline
fatherofone03 wrote: View Post
I was wondering if I could use a klipsch rs 3II as a center channel? I have klipsch rf 3II in the front and klipsch rs 3II in the back. I also have the matching klipsch 12" powered sub. I don't have the money for the matching center channel so I was wandering if I could use one of the extra rs 3II I have as a center channel until I can get the matching center channel?
Gooday Mr f .. With my setup for the centre i use Klipsch rf 35 . FL and FR rf 35 add surrounds rs35 which are dipole . It is so dam good most of the time I don't have to use my sub woofer .
Here is another idea .adjust your amp for NO centre channel as the imaging of the L and R Klipsch speakers should be so good they will image a centre . I have tried it and it works . Kind regards ,Alan .
Old 12-20-08, 01:24 PM   #8
Alias: tommy
Loc: Gulf Breeze, FL
User: #30573
Since: Dec 2008
  tommyboy1587 is offline
I definitely wouldn't use it. That speaker is WDST, wide dispersion surround technology. It "spits" sound at 180 degrees. You want a center that doesn't do that. It wouldn't sound right at all......
center, channel., klipsch
