| Home Audio Speakers Help picking Klipsch Synergy SpeakersDiscuss Help picking Klipsch Synergy Speakers in the Manufactured Speakers and Subwoofers forum; Help picking Klipsch Synergy Speakers My current setup includes a Sony STR-DG920 reciever, Klipsch Quintet surround speakers and Klipsch 12" subwoofer.
I'm looking to pick ... |
Views: 1436 - Replies: 10
| Help picking Klipsch Synergy Speakers My current setup includes a Sony STR-DG920 reciever, Klipsch Quintet surround speakers and Klipsch 12" subwoofer. I'm looking to pick up a set of floor standing speakers either the Klipsch Synergy F2 or F3 mainly to have more power when listening to music. I have a couple questions about how this change will affect my surround sound when watching movies. 1. Will I see any difference with the floor speakers as opposed to the small quintet satellite speakers? 2. Is there a big difference between the F2 and F3?... and do I need the F3's? 3. With the larger floor speakers will it be neccessary to pick up a larger center speaker the C2 or C3 or will I be ok with the center speaker from the Quintet? 4. Will I be ok with Quintet satellite speakers as my surrond speakers. Thanks, Aaron. Last edited by AaronJ; 11-30-08 at 09:25 PM.. | ||||
| | #3 | ||||
| Re: Help picking Klipsch Synergy Speakers First off, Welcome to the Shack. Second, I don't really know much about Klipsch but here goes; 1: Yes, especially if your room is very big. 2: Don't think so, the F-3 probably digs a little deeper. As for value and bang for the buck you'd probably be better off going with the RF-62 (priced right between the F-2 & F-3) I have not heard or read very many positive reviews of the Synergy Series but many people love the Reference Series. 3: Necessary,...No. Will you want to,...Yes, that is unless this is primarily a music system. It is important for the front three speakers to be sonically matched. That little Quintet will not do justice to the bigger floor standers. If this system is primarily for music it may not be that big of an issue for you. 4: Simple answer,...yes. But again, if this is primarily a movie system you will enjoy matched speakers much more than mismatched. Though it will not be a big issue using the Quintet's as surround. Mark | ||||
| | #4 | ||||||||
| Re: Help picking Klipsch Synergy Speakers Quote:
| | #5 | |||||
Also how would the surrounds differ from the F3's being from 35Hz to 23kHz vs the C3 being from 73Hz to 23kHz? Last edited by AaronJ; 12-01-08 at 08:49 PM.. | |||||
| | #6 | |||||||
![]() Quote:
![]() As you can see the F3 plays from 35Hz to 23KHz and C3 from 73Hz to 23KHz, so if you set the crossover at 80Hz you'll be fine ... Does your AVR has the autocalibration feature??? ...if it does, it will automatically adjust all speaker. | |||||||
| | #7 | |||||
If THX says to push everything below 80Hz to the subwoofer and I set the Tower speaker to small am I really going to gain anything for movies going from the Quintet to the Tower? It doesn't seem like it. It seems like I would gain from 80Hz to 120Hz with the Towers will having that range make that much difference? Last edited by AaronJ; 12-02-08 at 01:33 PM.. | |||||
| | #8 | ||||||
...somebody edited the post, I didn't read this the first time ![]() Yes that's correct ...you'll be able to set the crossover to each set of speakers. If you get the F2-F3 you can use 40Hz, for C2-C3 80Hz and for the Quintet surrounds 120Hz (or whatever the lowest frequency that it can handle) ![]() Use the autocalibration first, then manually adjust anything that is not set up properly; most of the time is distance, speaker size (small or large) and crossover frequency. If you don't own a SPL meter, I suggest you to get one to fine tune the speaker level (each one needs to read 75db and if you want 80db or 85db for the sub) Quote:
1) Set the front speakers (F2-F3) to small and cross it over @ 40Hz,60Hz or 80Hz 2) Set the F2-F3 to large ..then all bass from speakers set to small will be directed to Sub and any speaker set to large (fronts). You'll need to play with the set up to find out which one sounds better to you. In my case I'm using the second option because is how I get the best response .I'll recommend you to use REW (Room EQ Wizard) to fine tune your set up, is not hard to use ... ![]() | ||||||
| | #10 | ||||
| Re: Help picking Klipsch Synergy Speakers I did a similar setup using my existing Quintet III's as surrounds along with a Sub-12 and upgraded my fronts to the B3 bookshelfs with a C3 center. As Salvasol recommended, use the autocalibration first, then manually change settings as needed. You should purchase a Db meter (Radioshack or similiar) to assist with setup. You can try using your existing center, but you'll probably find you need to upgrade it to the C2 or C3. On my setup, I have the fronts set at 80hz and the 4 surrounds set at 120hz with the lpf of lfe set at 120hz for the sub. I think my setup sounds excellent setup this way. You can see my setup by clicking on "my photos" under my avatar. | ||||
| | #11 | |||||
1. Yes. Floor speakers will definitely sound better/louder 2. No. If you have a good sub, you don't need the F3 3. Get the C2 4. yes, for the time being. But upgrade to either S1's, or S2's later | |||||
