Room Problem- should I buy Martin Logan ESLs? - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 12Likes
post #11 of 37 Old 08-31-16, 09:47 PM
ellisr63's Avatar
Ron
Re: Room Problem- should I buy Martin Logan ESLs?
I had a pair of Martin Logans years ago, and my experience was they need lots of breathing room... preferably at least 3' from any wall to sound really good. This doesn't mean they won't work, but they will not be anywhere near their potential. Personally I think you would be better off with what you have or some speakers on stands to clear the couch if you can't give them the room they need.
Ron
My Home Theater
ellisr63 is online now
post #12 of 37 Old 09-01-16, 09:31 AM
Quenten
The only way I would consider them is after an "in-home" demonstration. If your dealer wont let you take them for a listen, then they are the wrong dealer!
And I agree that they will more than likely not preform well. There are numerous, quality bookshelf speakers that sound excellent & will get you above the couch like your speakers now.
Tonto is offline
post #13 of 37 Old 09-01-16, 10:40 AM Thread Starter
Peter
Ouch! To be fair to dealer I was there with a friend who was purchasing Sonus Faber speakers and parked myself in their small room with the EM ESL's. Thought they were great but did not have much conversation with dealer.
Dealer is an hour plus away so will try my experiment- listen to them with a 23" box in front of left speaker. AND if they sound ok there will bring them here on a "bring them back" basis if they don't work in my den.
Clearly I would love to get the planar sound in my room!
Thanks everybody. Will report back in a month or so when I get back to dealer.
Peter Orrick is offline
post #14 of 37 Old 09-01-16, 11:01 AM
Blacklightning's Avatar
Tonto wrote: View Post
Peter Orrick wrote: View Post
Ouch! To be fair to dealer I did not have much conversation with dealer.
I honestly would not even try it. Even if it sounds "OKAY" you are still missing out on all the potential. A pair of bookshelves would be way better for you. I see the 23" box test as a small problem, the real problem is that your speakers will not (can not) be 3 feet away from the side wall. But of course you can do what you want. I just hate going to someone's home and seeing there highend speaker in the corner playing away.
Tonto, ellisr63 and willis7469 like this.
Blacklightning is offline
post #15 of 37 Old 09-02-16, 09:47 PM
I'm gonna jump on the bandwagon here and say there are probably better options. Having line-of-sight from MLP to all speakers is more important to a good sounding room than having a speaker you really liked in a demo. Also, the electrostatics share a lot of principals with open-baffle designs, and there isn't any way around having some appreciable distance to the nearest hard boundary.
If you like the planar sound, (and you're absolutely right to prefer it and seek it out) there are options that might work a lot better in the space you have. I'd see if you can track down a small-format box, bookshelf size-ish, that has a ribbon tweeter or an AMT and audition those. Even if they don't sound as good to your ears as the ML's did in the demo room, they might just blow them out of the water in your space given all of the factors you have to deal with.
The funny part is that a forum of home theater nerds is trying to talk one of its own OUT of buying new speakers...
ellisr63 likes this.
DqMcClain is offline
post #16 of 37 Old 09-03-16, 01:05 PM Thread Starter
Peter
After multiple responses on this site and one other- the 100% consensus is without line of sight of whole speaker from MLP, full height ML dipole electrostatics will not work in my room. Also with centered Stewart screen cannot get MLs far enough away from side walls. I am calling it a day, NOPE!.
Has anyone had experience with stand mount dipoles? Below is an attached photo of Eminent Technology's stand mounted LFT-16A, the little brother to the highly regarded full height LFT-8b.
Does anyone have experience with this speaker or any other stand mount dipole?
As you can tell, I am still on my mission to make dipoles work in my den.
As always thank you for any advice.
post #17 of 37 Old 09-04-16, 06:01 PM
ellisr63's Avatar
Ron
For Dipoles to sound their best you still need to get them out into the room, if you can't then they are the wrong speakers for your situation IMO. Those are small enough to clear the couch, but I still believe they need room...at least these would be small enough for you to try out though.
Ron
My Home Theater
post #18 of 37 Old 09-04-16, 06:32 PM
ellisr63 wrote: View Post
Yup. That.
I think you'd be better served by a boxed design. There are plenty to choose from that incorporate ribbons, ring radiators, AMTs, and other non-dome tweeters that will bring the clarity you seek from the electrostatic drivers without all the complexity of placement that dipoles are saddled with.
I suppose it's theoretically possible to eat enough of the energy coming off the back of the dipole to trick it into thinking it is in a larger space than it really is... but I can't see that being cheap, aesthetically pleasing, or structurally feasible.
post #19 of 37 Old 09-05-16, 01:47 PM Thread Starter
Peter
Next week will head to dealer and have him put two ML EM ESLs on 18" or so stands (boxes?) and see how they sound. Am convinced now that left speaker cannot work behind sofa arm (all woofer frequencies below 500hz!).
Anyone here have experience with raising MLs on 18-20" risers in past? Did it work to your satisfaction? Did you have to tilt them forward to aim (slightly) down at 36" high MLP?
I realize my speakers will only be about 1 1/2 feet from side wall but right side wall has 4" GIK panel and left side window has a heavy liner drape. 4' to back wall for both.
Still on my mission to get planars into my den.
post #20 of 37 Old 09-06-16, 04:02 AM
New Member
Dean
I bought the Martin Logan ESLs about two weeks ago. My situation too is less than ideal due to room size and design. I had to place the ESL panels just two feet out from the front walls. They really would sound better at three or four feet out from the wall. But they still sound very good indeed. Perhaps it is because they are part of a 7.1 system and so the other speakers "fill in" for them. In your case, you are more restricted than me and that left speaker position, near the corner and with those curtains is problematic. A good room correction system might be be able to mitigate or surmount the situation. The Denon receivers at the higher end might be able to do the trick. Anthem and Yamaha's Aventage higher end receivers might work too.
You might consider the Martin Logan 60XT's or Motion 40's in place of the ESLs. Also a good subwoofer can make a big improvement in the sound from your current setup.
Anyway, see if you can audition the ESLs in your home and then decide, if your heart really is for those speakers. Also replacing the curtains with, say, wooden Venetian blinds, would help the back reflections from the electrostatic panel not to be suffocated.
deenie1219 is offline
buy , esls , logan , martin , problem , room
