Home Audio Speakers
How sweet the sound
Discuss How sweet the sound in the Manufactured Speakers and Subwoofers forum; How sweet the sound I listened to a set of Martin Logan Source's and really liked what I was hearing. But what I didn't ...
Views: 296 - Replies: 2
Old 01-13-09, 02:52 AM   #1
Alias: Don
BattlesD's Avatar
User: #32019
Since: Jan 2009
  BattlesD is offline
How sweet the sound
I listened to a set of Martin Logan Source's and really liked what I was hearing. But what I didn't like was that when you moved from that sweet spot the magic just went away. Don't get me wrong I know this is the case with speakers in general but the ML's really seemed to fall off. But man did I really dig what was going on in that sweet spot
Old 01-13-09, 09:40 AM   #2
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Re: How sweet the sound
Sonnie is a Martin Logan kinda guy , maybe he has some set-up tips that would help???
Mark
Old 01-13-09, 10:29 AM   #3
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
this is where properly seting up your speakers is a must. Sweet spots can be widened by speaker placement, sound absorbtion, distance from walls, receiver settings, etc. Keep reading, and you will find more info. I would think that the Martin's would have a wider dispersion than you experienced. Have fun, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
