Home Audio Speakers
Help! Truetech HTIB, No sound from speakers.
Discuss Help! Truetech HTIB, No sound from speakers. in the Manufactured Speakers and Subwoofers forum; Help! Truetech HTIB, No sound from speakers. Hello Everyone....I am new....and confused. Am a retired person with some knowledge of putting electronics together....but not this time. I ...
Views: 302 - Replies: 6
Old 01-15-09, 11:25 AM   #1
thaddypuss
Inactive
Alias:
User: #
Posts: n/a
Unhappy Help! Truetech HTIB, No sound from speakers.
I have a cheap Truetech home theater and have had it for 2 1/2 years. It was doing fine....a friend of mine who is no longer around set it up.
I moved two weeks ago (just across the street) and carried the speakers across the street. Another person set it up and could not figure out the directions. He must have done something right, because two speakers work. He insists he put the other 3 in the same way, but why, all of a sudden would the other 3 not work?
I can't afford to hire someone to put it together and I tried reading the directions myself, but too confusing.
Any suggestions? Does anyone think just unattaching the speakers and reattaching would "break" them?
Thanks so much for any help you can give to this old lady!
Old 01-15-09, 11:39 AM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
re: Help! Truetech HTIB, No sound from speakers.
Hi thaddy, welcome to the Shack.
I am thinking it may be just a button on the front of the main receiver that is selected wrong. Can you give me the exact model number of the theater system and I will have a look on the internet to see if I can find some pictures and instructions and help you.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 01-15-09, 01:00 PM   #3
thaddypuss
Inactive
Alias:
User: #
Posts: n/a
Oh, that would be great Tony.....I just don't understand this system, even though I hooked everything else up...TV, VCR, computer, etc. This system just blows my mind!
It is a Trutech....TDVD66048. Thanks.
Old 01-15-09, 01:32 PM   #4
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Hmmmm, I cant seem to find anything about that unit at all.
On the remote control is there any buttons labeled "effect" on off or "surround" on off? Does the main unit have any buttons on it possibly hidden behind a flap on the front?
Home theater:
Two Channel system:
My Webpage
Old 01-15-09, 01:49 PM   #5
thaddypuss
Inactive
Alias:
User: #
Posts: n/a
Actually, I am looking at the way he connected it, and he has it connected to my cable TV box.....don't think that is right....am going to have to sit down and try to do it all over again......this is going to take some time.....just don't see why it should be connected to cable box. The last time it was, I think, just connected from the TV directly to the home theater box....then I would put the TV input on Auxiliary....and it would work.....I HATE THIS!!!
Old 01-16-09, 10:01 PM   #6
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Help! Truetech HTIB, No sound from speakers.
thaddypuss wrote: View Post
Can you describe how (cables from/to, etc.) and what is connected to the system (TV, VCR, cable, etc.)??? ...It also could be that something is not setup properly ....
Try swapping the speakers that don't work with the ones that work to be sure they're fine.
Old 01-18-09, 03:25 PM   #7
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
I does sound like a setting on the receiver isn't right. Also, make sure that the audio out of the cable box is correctly connected to the receiver. The receiver must be set to accept the correct signal from the cable box. The surround settings can be incorrectly set. Maybe some pics of the back of the receiver and how you have connected it my help. Have fun, Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
help!
