Home Audio Speakers
Center channel recommendation.
Discuss Center channel recommendation. in the Manufactured Speakers and Subwoofers forum; Center channel recommendation. I picked up a pair of Dahlquist DQ20i's today and want to put them in my home theatre for a ...
Views: 325 - Replies: 3
Old 01-17-09, 09:39 PM   #1
Alias: Chris
Loc: Roanoke, Va.
User: #29102
Since: Nov 2008
  Natas is offline
Question Center channel recommendation.
I picked up a pair of Dahlquist DQ20i's today and want to put them in my home theatre for a while. What would be a good center channel to match with them? I currently am running a full Klipsch set up, but I do have an older Infinity center channel which I may use in the interim until a proper center for the Dahlquist can be had. I know very little about Dahlquist, so I'm not sure if they even have a center channel. Any help is greatly appreciated!!
Old 01-18-09, 09:34 AM   #2
Alias: Leonard Caillouet
lcaillo's Avatar
Loc: Gainesville, FL, USA
User: #328
  lcaillo is offline
Re: Center channel recommendation.
You want a speaker that sounds as close to the DQ20i as possible. I don't recall that speaker, but if they were anything like the old DQ10 it could be a tough match. I;d be looking for another of the same.
Note that we have now begun moving vendors to the new pull down option at the top of the forum pages. You will find it between "Shack Shopping" and "Glossary". This will represent a great improvement in the vendor reference database, making it easier than ever to find what you are looking for.
Contact me with any suggested entries, category recommendations, or additional information about the vendors that we have. If you are a vendor and want your company listed, there is an option to provide us with the information.
Old 01-18-09, 09:47 AM   #3
Alias: TC
Loc: Worcester Mass.
User: #9814
Since: Jun 2007
  tcarcio is online now
I agree, try to find another dq20i and use that. If not then maybe something from Infinity would be close.
Old 01-18-09, 09:52 AM   #4
Alias: Chris
Loc: Roanoke, Va.
User: #29102
Since: Nov 2008
  Natas is offline
Thanks for the responses! I know it's going to be hard to find a perfect match. I may wait until after I get them hook up and see if the centers I have sound good with them. Thanks once again!!
center, channel, recommendation.
