Home Audio Speakers
What speakers to remove going from 7.1 to 5.1
Discuss What speakers to remove going from 7.1 to 5.1 in the Manufactured Speakers and Subwoofers forum; What speakers to remove going from 7.1 to 5.1 Hey Everyone, I just upgraded yesterday to the RX-V663 and the 7.1 is very new to me. I know this ...
Views: 557 - Replies: 26
Old 01-22-09, 11:57 AM   #1
Alias: David13067
Loc: Milton, WV 25541
User: #32467
Since: Jan 2009
  David13067 is offline
Hey Everyone,
I just upgraded yesterday to the RX-V663 and the 7.1 is very new to me. I know this is a stupid question to the brillaint people on this forum but you should be able to give a a good answer.
I have the Boston Acustics MCS-100 Home Theater speakers so until I can get 2 more satelite speakers I'm connected 5.1. My question is which set of speaker do I eliminate for now? The surround or rhe back speakers?
Thank you,
David
Old 01-22-09, 12:09 PM   #2
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Rx-v663
Hi David,
This is a common question and confusing to new people in your situation. I wish receiver manufacturers would make this point much clearer in the instructions.
For a 5.1 speaker setup on a receiver capable of doing 7.1 you leave the "rear" speaker terminals empty. Even if you use the surrounds on your back wall you use the "side" surround terminals.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 01-22-09, 02:45 PM   #3
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Rx-v663
I'll second Tony's suggestion ....if you use a 5.1, leave the surround back empty. When you go into the main setup just tell the AVR you'll be using a 5.1 instead of 7.1 to avoid any problem with autocalibration
Old 01-23-09, 11:01 AM   #4
Alias: ginseng
bluejay's Avatar
Loc: Manitoulin Is., Ontario
User: #11443
Since: Sep 2007
  bluejay is offline
Re: Rx-v663
Welcome to the Shack.
I have the same receiver since December and really enjoy it.
Old 01-23-09, 01:43 PM   #5
Alias: David13067
User: #32467
Since: Jan 2009
Re: Rx-v663
That's how I have it set up. Do the side speaker and back speakers produce the same sound effects? Also I have not found the option for 5.1 anywhere. It just shows the speaker locations in the manual. So far, I really like the RX-V663. The local Bestbuy in Barboursville WV has the same Samsung BD-1500 blue ray and the RX-v663 set up for the in store surround sound demo's. the only differance is they have Polk Audio tower speakers and satelites. and it sounds amazing. I wish I could afford those polk audio speakers. My Boston Aucustics aren't too bad. I just need two more.
I also have two Optical Digital audio cables on order. Is this the best to use? My DVD only has Optical and Analog out but no Digital coax.
I appreciate all the transfer of knowledge.
David
Old 01-23-09, 02:09 PM   #6
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Rx-v663
David13067 wrote: View Post
The rear and sides will have different information sent to them if you have them both hooked up however if your only using 5.1 the information will be sent to only the sides.
David
If you dont have HDMI then optical is the best.
Home theater:
Two Channel system:
My Webpage
Old 01-23-09, 02:13 PM   #7
Alias: David13067
User: #32467
Since: Jan 2009
Re: Rx-v663
I am using HDMI. The optical out is for the audio. I didn't think the HDMI on the RX-V663 carried the audio. That's the way the Denon AVR-488 worked,
Thanks,
David
Old 01-23-09, 04:31 PM   #8
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Rx-v663
HDMI carries audio/video ...maybe you need to check the setting and be sure you assign HDMI to carry the audio; there's some AVR's that you have to use HDMI and optical/coax (I think is the case with the 488) but not with RXV663 (I own RXV 2700 and the HDMI carries both audio/video).
Old 01-28-09, 10:53 AM   #9
Alias: David13067
User: #32467
Since: Jan 2009
Re: Rx-v663
Thank you,
I did not know the RX-V663 carries video and audio. So I don't need any other cables than the HDMI to connect?
Thanks,
David
Old 01-28-09, 11:27 AM   #10
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Re: Rx-v663
If your device you have plugged into the receiver has a HDMI out then thats all you will need.
Home theater:
Two Channel system:
My Webpage
Old 01-28-09, 01:30 PM   #11
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Rx-v663
Yes, just be sure to use the correct settings on the AVR and input device (DVD, Cable/SAT, etc.) to get the audio through HDMI
Old 01-29-09, 08:51 AM   #12
Alias: David13067
User: #32467
Since: Jan 2009
Re: Rx-v663
Thanks,
I unpluged the analog cables last night and I have Video and Audio through the HDMI on the RX-V663.
Thanks Again..
Old 01-29-09, 11:07 AM   #13
Alias: David13067
User: #32467
Since: Jan 2009
Re: Rx-v663
Does anyone have a Speaker suggestion? $1,000+ per speaker isn't reasonable for me. Polk audio gets up there pretty quick. I have the 5.1 Boston Acustics system and thought getting a couple of floor standing front speakers would be a good way to move to 7.1.
Any suggestions welcome.
Thanks,
David
Old 01-29-09, 02:05 PM   #14
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Rx-v663
... I have the 5.1 Boston Acustics system and thought getting a couple of floor standing front speakers would be a good way to move to 7.1
That's a good idea ...visit Circuit City (now that they're closing maybe you can get a good deal)
What is the model of the system you have??? ...if they're small speakers, probably you'll be better buying a new system
Old 01-29-09, 02:50 PM   #15
Alias: Adam
Loc: Palatine, IL
User: #31101
Since: Dec 2008
  geniusadam is offline
Re: What speakers to remove going from 7.1 to 5.1
Keeping the front stage consistent is a good idea, so if you think about switching the fronts and surrounds of your current package to the sides and rears of a 7.1, then you should also consider investing in a center channel along with the floorstanders.
Old 01-29-09, 04:05 PM   #16
Alias: David13067
User: #32467
Since: Jan 2009
I have a Panasonic 56" rear projection LCD TV
Yamaha RX-V663
Samsung BD-1500
I just bought the Boston Acustics around first of the year and they sound great. The Subwoofer does a grest job but I feel like I'm still missing rhe big speaker sound.
Thanks
David
Old 01-29-09, 04:14 PM   #17
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
Your problem may be the size of your room, How large is it?
Home theater:
Two Channel system:
My Webpage
Old 01-29-09, 04:23 PM   #18
Alias: David13067
User: #32467
Since: Jan 2009
the Room is 20' x 23' with entrance to the kitchen on one side and a opening to the otherside that leads to a middle hallway behind the system. I don't think the room is all that large. Barely big enough to use 7.1 surround.
Thx,
David
Old 01-29-09, 04:28 PM   #19
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Yamaha RX-V663
Samsung BD-1500
Let's see if we can improve the sound ....
Does your RXV663 let you adjust the crossover to each speaker set (front+center+surrounds) or is just one crossover for everything???
Are you using 80Hz as XO frequency??? ...if the answer is yes, change that to 120Hz, that's the lowest your speakers can play (if you use less than 120Hz you'll have a gap between 80Hz-120Hz).
Sub is okay, but you're missing some audio. They're rated 45Hz-180Hz, and there's some movies that have audio to around 5/10Hz, I think you'll benefit from a sub that can play to at least 20Hz.
Can you still exchange the system??? ...if you do, try to get an Onkyo (5100, 6100 or 7100) their specifications are better than the one you have and it will sound a lot better.
Old 01-29-09, 04:44 PM   #20
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
That's a big space for the sub ...is rated 100 RMS, 45Hz-180Hz
My room is 9'x18'x8' closed and I was using two subs 150RMS each and 35Hz-180Hz, definetelly I think you need a bigger sub
Old 01-29-09, 05:04 PM   #21
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
salvasol wrote: View Post
I agree, Thats a very large space for those speakers and the sub. Not to mention is almost a perfect square.
You need to look at at least getting a better sub if you really want to have that punch your missing.
My room is 16'x 37' and I have a quite a big sub and it works very hard to fill the space.
Home theater:
Two Channel system:
My Webpage
Old 01-29-09, 08:23 PM   #22
Alias: David13067
User: #32467
Since: Jan 2009
My sub doesn't sound bad. I have hardwood floors and the Boston Acustics Sub pushes down.
Old 01-29-09, 08:37 PM   #23
Alias: Pinhead
User: #30763
Since: Dec 2008
  Pinhead-227 is offline
Re: Rx-v663
DO NOT go to Circuit City if you're trying to get a good deal!! LOOK HERE for why you don't want to buy at CC!!!
Old 01-29-09, 08:48 PM   #24
Alias: David
salvasol's Avatar
Loc: Fontana, CA
User: #3627
Since: Oct 2006
  salvasol is offline
Re: Rx-v663
Pinhead-227 wrote: View Post
That's true ...and most companies do the same (that's why is a good idea to check prices to know when is a good deal or not), I always make a joke: 50% off of the 100% increase
Also, most sales are finals ...but let's say if the speaker cost $300 and he can get it for 1/3 I think is a good deal ...I'm a bargain hunter, that's why I always go to BestBuy and other stores at least once a week to know the prices and to be prepared for a real good deal (I got my Yamaha RXV 2700 for $399.99, regular price $1200 at that time)
Old 01-29-09, 09:07 PM   #25
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is offline
45Hz is no where near low enough to reproduce what you really want. Movie soundtracks go well below that. A down firing sub wont improve how well it preforms other than giving you a little more at the lower end of its range and it only goes down to 45Hz.
Home theater:
Two Channel system:
My Webpage
rx-v663
