| Home Audio Speakers Rearranging speakersDiscuss Rearranging speakers in the Manufactured Speakers and Subwoofers forum; Rearranging speakers I have a set of PSB 4T's as the front speakers on my home theater system and PSB 1B's as ... |
Views: 718 - Replies: 2
| Rearranging speakers I have a set of PSB 4T's as the front speakers on my home theater system and PSB 1B's as the rears. I am planning on buying a new 42" plasma and won't be able to keep the towers in the front due to space limitations. The amp is a Denon 3803. If I switch towers, the 4T's to the rear and some how can get the smaller 1B's to the front, is there some way I can configure the Denon so that I'll still get a quality surround sound? | ||||
| | #2 | ||||
| Re: Rearranging speakers I think there isn't anything you'd change.. I'm assuming that you have your receiver set to "small" for all speakers, including the towers. Other than that, I think you should be fine. I'd assume you'd lose some quality moving to a more modest speaker for your fronts, but that's going to be unavoidable if you have space issues. Good luck and let us know how it turns out. Jacen | ||||
| | #3 | ||||
| Re: Rearranging speakers Hi gerry and welcome to the Shack! I assume you don't want speakers out in front of the Plasma set.... surely the width of a Plasma is not causing you space limitations. How exactly is your space limited? | ||||
