Home Audio Speakers
My Speakers...
Discuss My Speakers... in the Manufactured Speakers and Subwoofers forum; My Speakers... Hey Guys! This is my setup. Harman Kardon AVR 254 Yamaha 10 in powered Sub Yamaha in ceiling rear speakers ...
Views: 598 - Replies: 38
Old 02-11-09, 12:20 PM   #1
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
  newyorkmets54 is offline
My Speakers...
Hey Guys!
This is my setup.
Front and Center Channel using Onkyo 5.1 system speakers that came HTIB. They are small speakers.
How much am I hurting my Home Theater experience with these as my front and center speakers?
I was thinking of getting some Yamaha Floorstanding speakers. I don't want to spend too much (less than 500) for something better. Any ideas?
I mean I got this great new receiver but still using these speakers.
Unless these onkyo speakers aren't bad afterall. Let me know!
Thanks to all!
Old 02-11-09, 12:25 PM   #2
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Re: My Speakers...
Of course, the best speakers are the ones you like. There are several speakers out there (SVSound, among others) that will most likely sound better than HTIB speakers. You should get some time listening to better speakers at different stores in your area. Have fun. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 02-11-09, 12:36 PM   #3
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
Re: My Speakers...
The key thing is to have the front three speakers (L,C,R) of the same brand and preferably the same line.
How large is the room you have this system in?
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 02-11-09, 12:42 PM   #4
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
15X10 or so. Its a second bedroom converted to my video game/cinema room.
The L/C/R are matched all onkyo htib speakers.
Old 02-11-09, 12:50 PM   #5
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My Speakers...
You would probably notice a difference if you got something better, However i would not call Yamaha speakers much better.
The SVSound speakers seen here would be a huge step up from what you have and within your budget.
You could also use a better sub but for now I would concentrate on your fronts.
Home theater:
Two Channel system:
My Webpage
Old 02-11-09, 01:26 PM   #6
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
Are they a small speaker? And your saying its going to be night and day difference?
Old 02-11-09, 01:36 PM   #7
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is online now
Re: My Speakers...
As Dennis points out, the best speakers for you are the ones that you like. The SVS is a good suggestion, but don't count out Yamaha either. If you like the sound of your current Yamaha speakers you may find you like the NS-333 for a bookshelf, the NS-555 for towers or NS-C444 for center channel duties. Many people find the Yamaha's to be clear, crisp, and pleasant to listen to and not too hard on the budget, though the Yamaha towers will likely blow your budget unless you find a deal on them.
Mark
Old 02-11-09, 01:41 PM   #8
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My Speakers...
There an average bookshelf sized speaker. 12" x 7" x 9.5" and yes I would say a big difference in clarity.
Home theater:
Two Channel system:
My Webpage
Old 02-11-09, 01:59 PM   #9
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
Another problem I am having is the placement of my center channel speaker. I have the speaker right now on top of my AVR. Its a small center channel and is not covering much of the top of the receiver at all. How large are these center channel speakers? Because I've seen some HUGE ones. Way to big for my application.
Old 02-11-09, 02:27 PM   #10
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My Speakers...
the svs center channel is 7" x 20" x 8.5".
Do you space to go higher above the receiver? you could use some blocks or foam peices under the sides to raise the center channel about 3" leaving the space needed for air movement.
Home theater:
Two Channel system:
My Webpage
Old 02-11-09, 03:29 PM   #11
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
I'm looking online at teh SVS and the Yamaha. Is it worth the extra 100 dollars or so for the 2 bookshelf SVS with center channel or the yamaha?
Old 02-11-09, 03:39 PM   #12
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My Speakers...
There are several people on this forum who have the SVS speakers and all of them are very happy with them I would bet to say the they are well worth the extra $100
Home theater:
Two Channel system:
My Webpage
Old 02-11-09, 04:58 PM   #13
Alias: Adam
Loc: Palatine, IL
User: #31101
Since: Dec 2008
  geniusadam is offline
Re: My Speakers...
This may get me yelled at, but i'm skeptical of svs speakers. It's true i haven't heard them, but I find it unusual that speakers that are so superb (if you look around on these forums, you'll see everyone says they're amazing) are not far more popular than they are. From the acclaim that i hear here, it seems everyone in the world should have them, esp. since they're reasonably priced (like 500$). Anyways, i would say your best bet if you were serious about the upgrade would be to wait on these, save up some money and buy some better speakers. There are a variety of brands, but I think you'll greatly appreciate the huge step-up. Anyways, just my two cents.
Old 02-11-09, 05:00 PM   #14
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
Hey tony, I don't think that these center channel speakers are going to fit where I have my receiver. Is there anything smaller that will do the trick? Thanks for the newb info
Old 02-11-09, 05:08 PM   #15
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is online now
Re: My Speakers...
It depends on what you want. I'd definitely say you'll want to get the front three to match. As for the $100 difference,... the Yamaha towers are priced per speaker, not per pair. So you'd be looking at about $650 vs. $410 plus shipping for the SVS. The Yamaha bookshelf's are per pair, so that set you'd be looking at $348.
As for whether or not one is "worth it" over the other,.... well, only you can decide that . It's very seldom you hear anything negative about SVS. My preference would be for towers and at your budget I'd probably be looking at this Energy C-300 5.0 or Energy C-300 5.1 package set right now.
Mark
Old 02-11-09, 05:10 PM   #16
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My Speakers...
geniusadam wrote: View Post
Understandable, I think you forget that there are alot of fantastic quality speakers and A/V equipment manufacturers that only sell on line. Yes, this limits there exposure but that does not make them unreliable or poor quality. I personally own there best subwoofer they make and it blows away anything I have heard in any local store for anywhere close to the price.
newyorkmets54 wrote: View Post
The problem with going smaller is that you loose the dynamics that a lager enclosure gives you. Could you place the center channel above the display?
Home theater:
Two Channel system:
My Webpage
Old 02-11-09, 05:13 PM   #17
Alias: Adam
Loc: Palatine, IL
User: #31101
Since: Dec 2008
Re: My Speakers...
tonyvdb wrote: View Post
I agree with this statement. I think there is always a way with rearranging to fit everything. The larger enclosures will give you a much better range.
Old 02-11-09, 05:20 PM   #18
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is online now
Re: My Speakers...
Have you considered a center speaker stand? Is it possible to place it above / on top of the TV, or perhaps placing it on a small CRT TV wall mount like this ? or if you have a wall mounted LCD/Plasma something like this ?
There are many options out there for most any situation.
Mark
Old 02-11-09, 05:34 PM   #19
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
The issue that I am having is I already have the rear speakers in my ceiling. Yamaha's. So all I need is the two front and a new center channel. However, I can't get a center that is very big as I dont have the room.
Old 02-11-09, 05:36 PM   #20
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My Speakers...
could you post a picture of your setup to help us come up with something that will work?
Home theater:
Two Channel system:
My Webpage
Old 02-11-09, 05:36 PM   #21
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
If I place the center channel above the display, then the center will be above the left and right speakers.
Old 02-11-09, 05:39 PM   #22
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
I work until 9. I will try and post a pic tonight when I get home.
Old 02-11-09, 05:41 PM   #23
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
Re: My Speakers...
sometimes a person has to give up a little bit of the rules to make it work and in your case this is a good compromise to make in order to get a good sounding center channel. do you have more than one row of seating? if not then all you have to do is angle the center slightly down so the tweeter still fires at your listening position and it will be just as good.
Home theater:
Two Channel system:
My Webpage
Old 02-11-09, 05:57 PM   #24
Alias: Chris
Loc: New Jersey
User: #32407
Since: Jan 2009
Re: My Speakers...
No no, just one nice recliner couch. Ill post a pic and we'll see.
Old 02-12-09, 02:03 PM   #25
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
Re: My Speakers...
That's ok -- it's not "ideal", but it's the way most systems I've seen work. You just want to have the speaker angeled towards the sweet spot.
And I'll put it out there, I think you will definitely hear a night and day difference between the SVS's we're mentioning and the Yamaha's. That doesn't mean you'll like them more -- although, I'd put a lot of money on it.
As for the skeptism for the the SVS, I can totally understand where you're coming from. However, I think the reasons mentioned (internet only company) explains away the issue. There are other internet only companies that are similarly praised but aren't known by the masses simply because they don't see them in their local big box store.
And back to the OP -- I really recommend that you go to some of the smaller boutique stores and have a listen to those setups. I think you'll be surprised at what you hear in your price range.
speakers...
