Home Audio Speakers
Klipsch new guy question
Discuss Klipsch new guy question in the Manufactured Speakers and Subwoofers forum; Klipsch new guy question hey , guys im new to this whole spkeaker thing so i decided to try something else besides those HTIB ...
Views: 316 - Replies: 2
Old 02-15-09, 06:01 PM   #1
New Member
Alias: osmosis600
User: #34041
Since: Feb 2009
  osmosis600 is offline
hey , guys im new to this whole spkeaker thing so i decided to try something else besides those HTIB ones. I found the KLIPSCH F-1 system (2xf-1s,1xc-1,2xs-1,1Xksw sub) for 940$ + free shipping, i was wondering if theres anything better for this price range? i looked and looked and could not find anything else for this cheap. Its a small room and im really on a budget , what do you guys think
Old 02-16-09, 10:44 AM   #2
Alias: Jay
jackfish's Avatar
Loc: Western Wisconsin
User: #5100
Since: Dec 2006
  jackfish is offline
Re: Klipsch new guy question
Will you get a chance to listen to them before you buy? If you can and like it then that's all that matters. You could do a lot worse. Are you sure it is a KSW sub and not the Sub-10? The new Sub-10 is a little more robust than the KSW-10.
In a small room that system should be good, if you like the Klipsch sound.
Old 02-16-09, 10:58 AM   #3
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Welcome to the Shack. Have fun. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
klipsch, question
