| Home Audio Speakers Speakers horizontal vs verticalDiscuss Speakers horizontal vs vertical in the Manufactured Speakers and Subwoofers forum; Speakers horizontal vs vertical What if any are the reasons for not placing speakers on there side ( horizontal vs vertical) Is there a ... |
Views: 878 - Replies: 7
| Speakers horizontal vs vertical What if any are the reasons for not placing speakers on there side ( horizontal vs vertical) Is there a audible difference? I placed my surrounds on there sides so I dont bang my head on them when walking by/under them as I am 6'4" tall. Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #2 | ||||
| Re: Speakers horizontal vs vertical Tony..I'm no expert but my understanding is that it has something to do with the dispersion pattern.. Speakers that have a vertical array of drivers, radiate more sound to the sides than up or down, when mounted in the vertical position.. This of course helps to give a good sound stage across a screen, from your L&R speakers.. Likewise for surround speakers..They need to be placed in a manner that will give the best flow of sound from front to back.. If they are designed to be mounted vertically (as most surrounds are), mounting them horizontally will diminish that flow of sound.. Others more experienced than myself might have other ideas though.. Prof.. Home Theatre...the never ending story! | ||||
| | #3 | ||||
| Re: Speakers horizontal vs vertical Thanks Prof, Thats was my thinking as well but wanted to know if it really matters. The Mission 762's are not a small speaker and have an 10" driver and a silk dome tweeter with a port above the tweeter. ![]() Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #4 | |||||
| Re: Speakers horizontal vs vertical Quote:
Kal | |||||
| | #5 | ||||
| Re: Speakers horizontal vs vertical Thanks Kal, I guess its about compromise. I will have to see if I can make it work having them mounted the proper way. Just have to watch my head.Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| | #6 | |||||
![]() I'm using this JBL's and they can be used either way ... | |||||
| | #7 | ||||||
Kal | ||||||
| | #8 | ||||
| Re: Speakers horizontal vs vertical Well I managed to mount them properly last night so everything is the way it should be. ![]() Home theater: Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2 Two Channel system: Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub My Webpage | ||||
| Bookmarks |
| Tags |
| horizontal, speakers, vertical |
| Thread Tools | |
