Home Audio Speakers
surround speakers must match the front?
Discuss surround speakers must match the front? in the Manufactured Speakers and Subwoofers forum; surround speakers must match the front? I got a flat screen TV in October, HD TV in December, then I caught the Home Theatre bug and ...
Views: 974 - Replies: 9
Old 02-20-09, 10:00 PM   #1
Alias: Dwayne
User: #34303
Since: Feb 2009
  punman is offline
I got a flat screen TV in October, HD TV in December, then I caught the Home Theatre bug and bought a new receiver and speakers. I bought KEF iQ5s for front and iQ2 for centre. I have a cheapie subwoofer that I want to upgrade in the summer but that is another issue. Harmon Kardon 146 AVR.
I have been using my 25+ year old EPI 100s for the surrounds.
I was thinking of KEF iQ1s for surrounds. I can afford to do that but maybe it is wasting money if I can evaluate my EPIs. But maybe EPIs are so radically different that I should not put them to use in the KEF scheme of things even if they are functioning properly. Maybe my EPIs are "too much" speaker for surrounds with the KEFs and I should use the EPIs for something else?
Even if you know nothing of EPI or KEF please respond to how important you think it is that the surround speakers match the front by the same brand/line.
The KEF iQ1s are on sale for $248 Canadian ($200 U.S.) for the next week instead of thier usual $400 a pair ($320 U.S.) so it would be a good time to make the move if I am going to. I have only had the EPIs hooked up as surrounds for two weeks. They seem pretty good when hooked up as regular speakers but as surrounds I have to set the AVR to +6 decibels to get proper sound, even though they are closer to the listener than the fronts.
Old 02-21-09, 10:16 AM   #2
Shack Moderator
Alias: Dr Doan
Loc: Oklahoma City, OK
User: #2314
Since: Aug 2006
  drdoan is offline
Re: surround speakers must match the front?
Hi Dwayne, welcome to the Shack. The surround speakers are not nearly as important to match the system as the front and center speakers. If you place them correctly, level match them, and they have similar efficiencies, you should be ok. The main thing is: do they sound good? Have fun. Dennis
L Dennis Doan, DC
Gonstead Chiropractor
IT'S THE NERVE!
www.drdoan.com
www.healedthefilm.com
SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers)
Klipsch RS-42 side surrounds
SVSound SB12-Plus/2 sub (w/12.3 drivers)
AS-EQ1 Sub Equalizer (WOW!)
Denon AVR-2807 Receiver w/AudysseyXT
Toshiba DVD Recorder w/HDMI
Direct TV DVR HD
BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen
15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption
Old 02-21-09, 10:38 AM   #3
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
  eugovector is offline
Ditto.
Old 02-21-09, 10:56 AM   #4
Shack Moderator
Alias: Mark
nova's Avatar
Loc: Northern Utah
User: #278
  nova is offline
Hi Dwayne, here are my thoughts;
I like all my speakers to have the same drivers and be from the same speaker line from any particular manufacturer. I think you get a fuller more enveloping sound, with hopefully seamless pans as the sound travels around the room. It should also make it easier to set up properly and take one more possible issue out of the equation.
Do I think it's terribly important to have all matching speakers? No. Many people set up systems with mix-n-match speakers and they sound great. Now to contradict my previous statement, I'd also think it's possible for mix-n-match to work better in a room, there could be placement issues, resonant room modes, or other acoustic issues that may cause problems. It's possible that different speakers could actually help.
I think there are enough variables that the only way to really know is to listen to the speakers in your room and decide if you like or can hear a difference from one to the other.
Mark
Old 02-21-09, 06:12 PM   #5
Shack Moderator
Alias: Prof.
Prof.'s Avatar
Loc: South of Adelaide
User: #3204
Since: Oct 2006
  Prof. is online now
nova wrote: View Post
That's a good point..
Even with identical speakers around the whole room, you would hear tonal differences from the fronts to the surrounds, just with the different speaker locations and room acoustics..
Prof..
Home Theatre...the never ending story!
Old 02-21-09, 07:41 PM   #6
Shack Podcaster
Alias: Marshall
eugovector's Avatar
Loc: Salem, OR
User: #2411
Since: Sep 2006
Prof. wrote: View Post
But this would really only be a big problem with front to back pans, which aren't as frequent as left to right. Ambient music and effects wouldn't reveal tonal differences as easy as pans.
Old 02-21-09, 07:50 PM   #7
Shack Moderator
Alias: Prof.
Prof.'s Avatar
User: #3204
Since: Oct 2006
  Prof. is online now
eugovector wrote: View Post
Totally agree..
Prof..
Old 02-23-09, 02:31 PM   #8
Alias: John
PT800's Avatar
Loc: Nevada
User: #17108
Since: Feb 2008
  PT800 is offline
With identical speakers all around, there will be very difference in timbre match, to the point of not noticing a difference. Even if the LCRs are free standing and the surrounds are all wall mounted. The main difference, in that setup, would be the freestanding mains would have deeper soundstage, and the surrounds would have a slightly more pronouced mid-bass due to boundry reinforcement.
Performance Series
the name sez it all
Old 02-23-09, 04:59 PM   #9
Gold Supporter
Alias: Tony
tonyvdb's Avatar
User: #11319
Since: Sep 2007
  tonyvdb is online now
In some cases this is simply not possible as if you have towers for example it would be very tough to mount the same towers on the rear walls as required by Dolby specifications due to the weight. Generally as has been said matching the fronts is best but again most can not make a center tower speaker fit there system due to it blocking the screen or display.
I think the so called matching is more getting a speaker that is from the same line of speakers.
Its all about compromise and of course the WEF.
Home theater:
Onkyo TXSR805, Samson Servo 4120 4 ch amp bridged @240wattsX2
Mission 765 Mains, 4-762i's Surrounds, AR center PSC25, SVS PB13 Ultra & A/D/S MS3u sub
2 Audio control C131 EQ's, Toshiba XA2, Samsung BDP1400, Pioneer LD
Sanyo Z4 pj, Viewsonic N3235w 32" HDTV
Two Channel system:
Yamaha RXV995, Mission 764i's, Yamaha YST FSW100 sub
Yamaha KX-393 Tape deck, CDC 805 CD changer, LG DV7832NXC DVD, Sony turntable PS-T20, Nintendo Wii
Sony KP-53HS30 HDTV, Motorola HD-PVR
My Webpage
Old 02-23-09, 06:09 PM   #10
Alias: John
PT800's Avatar
Loc: Nevada
User: #17108
Since: Feb 2008
  PT800 is offline
tonyvdb wrote: View Post
No one ever said all speakers work at all positions, but many will. Any speaker that is 24" tall or less will generally fit between the floor and bottom of a rptv or a flat panel mounted at the same elevation. Something like this.
Performance Series
the name sez it all
front?, match, speakers, surround
