Indirect or Direct Surround Speakers - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Home Audio Speakers
Discuss Indirect or Direct Surround Speakers in the Manufactured Speakers and Subwoofers forum; Indirect or Direct Surround Speakers I currently have bipolar surrounds and they sound decent enough, but they have no authority and mediocre fidelity. I'm thinking ...
Old 09-12-06, 06:44 PM   #1 (Link)
Alias: jagman
Loc: Sacramento, CA
User: #1455
jagman is offline
I currently have bipolar surrounds and they sound decent enough, but they have no authority and mediocre fidelity. I'm thinking a change might be in order. What are your preferences?
Old 09-12-06, 09:02 PM   #2 (Link)
JCD
Golden Bear Mod
Alias: Jacen
Loc: Bay Area, California
JCD's Avatar
User: #53
JCD is offline
Re: Indirect or Direct Surround Speakers
I have Dipoles right now -- if the room was situated perfectly, I say dipoles might be the way to go.
However, if your room is anything like mine, it's not set up ANY WAY NEAR perfect. For that reason, I'd vote for directs.
JCD
Old 09-12-06, 09:39 PM   #3 (Link)
Loc: Lower Alabama
I have heard that bipole and direct will give you more bass than dipole, but I don't have any proof... just the word of Brian Cheney at VMPS, whatever that might be worth.
Sonnie
Old 09-13-06, 10:04 AM   #4 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Ayreonaut is offline
I like using four direct surrounds.
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 09-13-06, 01:51 PM   #5 (Link)
Alias: jagman
Loc: Sacramento, CA
User: #1455
jagman is offline
I'm thinking about the approach GR Research is thinking of building. It has a 36" tall colum like enclosure with a BG Neo 3 PDR firing straight at the listeniner and a 5.25" woofer firing straight up. Sort of does the direct and indirect thing. The idea is it would be a floor standing rear/surround speaker that is tying to get the best of both worlds. I think this or purely direct radiators would work best for my room given the amount of acoustic room treatments.
Old 09-13-06, 04:09 PM   #6 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
I built the GR-Research AV1RS designs, much better than direct radiating. I used to have all 5 of the exact same MTM AV2's and much prefer the AV1RS for surrounds. More ambient, larger soundstage.
Old 09-21-06, 08:30 AM   #7 (Link)
Alias: saabman
User: #2582
Since: Sep 2006
Bruce is offline
Darren,
I'm assuming this is a 5.1 config, correct ?
Where are those AV1RS surrounds located with respect to the listening position ?
What size room ? I know your rearranging your website, how about a simple room layout diagram of speakers and seating with room dimensions ?
Love that IB !!!
Old 09-21-06, 08:54 AM   #8 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Yes, it is currently a 5.1 config but they are also very good in 7.1 systems as side and surround. These speakers can be placed either on the side wall or rear wall. They should be 2 feet from the adjacent corner in either position and 16" from the ceiling. I have mine on the side wall 16" from the ceiling about 2 feet behind the listening position. It is unreal how well they disperse the rear soundstage. Very open.
I'll see about getting a room diagram made up soon! Maybe today
Darren
Old 09-21-06, 09:31 AM   #9 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Ok, how's this? It isn't perfectly to scale but gives you the idea...
The center channel had to be mounted in the ceiling portion, no other possible location due to the brick wall behind the plasma. It integrates surprisingly well though. Very little baffle step issues even thoug it is recessed into the ceiling. I may change the center to a similar AV2 design that was designed with no baffle step loss to get that improvement though.
Old 09-21-06, 10:24 AM   #10 (Link)
Alias: saabman
User: #2582
Since: Sep 2006
Bruce is offline
Wow . . . .
Great, fast response. Thanks.
Yea, I was also wondering about 7.1 as well.
I currently have 5 Dynaudio Contour speakers (all direct radiators) and I was trying to figure out what to do about back surrounds vs side surrounds. This would be a Logic 7 capable HK 240 rcvr being used as only a prepro. The real question for me becomes how well the AV1RS would integrate with my Dyns. It seems like it would be worth trying and if they didn't work I could sell them. Maybe I even replace my current Dyn surrounds with another pair of AV1RS. Just thinking out loud.
Old 09-21-06, 08:47 PM   #11 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
I think they'd integrate wonderfully. I love the Dynaudio sound which is what attracted me to GR-Research...very similar in my opinion. I used to have 5 AV2's all direct radiating and I switched to the AV1RS for my surrounds for better WAF and in hopes that it would be an improvement on my surround effects. It turned out to be a HUGE improvement on rear effects. No longer are they localized, they are more ambient and the effects travel around the room much more convincingly.
Old 09-22-06, 08:45 AM   #12 (Link)
Loc: Lower Alabama
Wouldn't this thread be more appropriate in the Speakers forum? I'm gonna move it there.
Sonnie
Old 11-04-06, 04:51 PM   #13 (Link)
Shack Moderator
Alias: Mark
Loc: Northern Utah
nova's Avatar
User: #278
nova is offline
Another approach (one that I really like) is the Bi-Di speakers. My 66-SE surounds have Bi-Polar woofers, and Di-polar tweeters.
Mark
Similar Threads
HD video direct from IFA 2006 HDBeat Home Theater, Audio and Video News 0 09-08-06 11:10 AM
Surround Speakers? Darrel Hawthorne Home Audio Speakers 34 08-11-06 01:56 PM
Anthem's Statement D2 Surround Sound Preamp/Processor Sonnie Home Theater Components 6 06-20-06 11:29 AM
Yamaha YSP-1000, Surround Sound Projection Wayde Home Theater, Audio and Video News 0 06-12-06 08:11 PM
Revel F52 Floor-Standing Speakers, C52 Center Channel Speaker, S30 Bookshelf Speakers Sonnie Home Theater, Audio and Video News 0 06-02-06 08:33 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
