| Home Audio Speakers Best Home 5.1 Theater for an apt.Discuss Best Home 5.1 Theater for an apt. in the Manufactured Speakers and Subwoofers forum; Best Home 5.1 Theater for an apt. I am buying an Onkyo TX-SA606X and hooking up my HTPC to it. I now need a 5.1 speaker system ... |
Views: 502 - Replies: 16
| I am buying an Onkyo TX-SA606X and hooking up my HTPC to it. I now need a 5.1 speaker system for my apartment which is 8 ft wide and about 12 feet long with walls in front and behind the sofa/TV with a sliding glass door for the right wall and an empty spot on the left where the entry to the kitchen is (don't know if all that's necessary, but I'll say it anyways... I am looking for a center, sub, 2 bookshelf fronts and 2 wall mounted surrounds. I'd like to buy everything for under 1000 bucks. I do not listen to music much. I mostly watch movies, and my wife watches TV. Thanks for any help you might give me. I have seen people recommend B & W, Paradigm, Klipsch and many more. Any help would be great. Thanks. | ||||
| | #2 | |||||
| Re: Best Home 5.1 Theater for an apt. Quote:
Hey samhfoley welcome to the shack!! ![]() I would recommend the SVS or Emotiva, I have the SVS and they sound good! ![]() ![]() | |||||
| | #3 | ||||
| Re: Best Home 5.1 Theater for an apt. WHich SVS system specifiaclly would you recommend, and what are you using currently? The SVS set is under 1000 without the sub. With the sub I think it's well over 1000, but I could be wrong.... Last edited by samhfoley; 03-11-09 at 11:04 PM.. | ||||
| | #4 | ||||
| Re: Best Home 5.1 Theater for an apt. Well you said under $1000, so you have to pick a package that's good for you( )I have the SCS-01 center and 4 SBS-01 for the front and rear, dont have a sub with that system, but I d had a SVS 2039 sub and it was great! ![]() https://svsound.com/products-sys-sbs_black.cfm | ||||
| | #6 | ||||
| Re: Best Home 5.1 Theater for an apt. Good luck!! I just noticed that your in japan , hopefully they would shipped to Japan with out costing a fortune!![]() | ||||
| | #7 | ||||
| Re: Best Home 5.1 Theater for an apt. I'll be back in the US visiting family this summer and will pick them up then and bring them back to Japan. Whether or not they are under the weight requirement for the plane is another matter altogether! | ||||
| | #8 | ||||
| Re: Best Home 5.1 Theater for an apt. For the money, you just can't go wrong with SVSound SB and SC system. Have fun. Dennis L Dennis Doan, DC Gonstead Chiropractor IT'S THE NERVE! ![]() www.drdoan.com www.healedthefilm.com SVSound SBS-01 fronts, center, rear surrounds (I was honored to be the 1st purchaser of these great speakers) Klipsch RS-42 side surrounds SVSound SB12-Plus/2 sub (w/12.3 drivers) AS-EQ1 Sub Equalizer (WOW!) Denon AVR-2807 Receiver w/AudysseyXT Toshiba DVD Recorder w/HDMI Direct TV DVR HD BenQ W5000 projector mounted on ceiling. 91" MovieTime pull-down screen 15' x 11.8' vaulted ceiling dedicated HT room w/DIY sound absorption: | ||||
| | #9 | ||||
| Re: Best Home 5.1 Theater for an apt. What about wiring? On the SVS page they offer 3m of BetterWiring for 55 bucks a pop and 114 for the 8m, that would run me 338 for all 4 speakers, what is a cheaper, but still quality, alternative | ||||
| | #10 | |||||
(actually - any real subwoofer!) Do you realize even the PB10NSD is 60 lbs? And then I think of getting it in through customs. ![]() Guess if shipping is too high, I'd give serious thought to something you can buy there. good luck! | |||||
| | #11 | ||||
| Re: Best Home 5.1 Theater for an apt. well that IS A BIT HEAVY! LOL I just had an espresso machine and grinder shipped here from Canade and it was about 400 bucks for shipping. I think it'll be cheaper to pay the overweight charge on the flight back. There's also the possibility of buying the SVS system without the sub and buying that on my next trip home in 2 years time... | ||||
| | #12 | ||||
| Re: Best Home 5.1 Theater for an apt. Another option is to buy the SVS speakers and build the sub in Japan(DIY) ![]() ![]() | ||||
| | #13 | ||||
| Re: Best Home 5.1 Theater for an apt. I have built computers before, but never audio equipment. Wouldn't know the 1st thing about a DIY sub project. Know any good sites/URLs with advice on the subject? The problem with Japan is the cost of pretty much everything is astronomical. The espresso machine I just bought and had shipped over here was about 1600 USD from a Canadian shop. The same machine, in Japan, costs 3,335 USD. Just staggering the cost of high end gear here... | ||||
| | #14 | ||||
| Re: Best Home 5.1 Theater for an apt. you don't have to go to far to check out some DIY......... http://www.hometheatershack.com/foru...rs-subwoofers/ | ||||
| | #15 | |||||
| | #17 | ||||
| Re: Best Home 5.1 Theater for an apt. Give it a shot. I don't think it could be that bad. | ||||
| Bookmarks |
| Tags |
| budget, compact, home theater |
| Thread Tools | |
